Old 12-11-2014, 11:43 AM   #1
a-bone newby
a-bone newby's Avatar
Default motors
does any body rering and valve lap a engines without complete overhaul
a-bone newby is offline   Reply With Quote
Old 12-11-2014, 12:24 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: motors
I would if the babbit is good. In fact I'm wishing I had done that with an engine that had no shims and original babbit.
Old 12-11-2014, 12:26 PM   #3
jkeesey
jkeesey's Avatar
Default Re: motors
Yup, done it several times.
jkeesey is offline   Reply With Quote
Old 12-11-2014, 02:22 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
Default Re: motors
I always overhaul my engines. I use to just lap the valves. A few years ago I got better valve tools. I now cut the seats and install new stainless steel valves from Snyders. It makes a big difference . Lapping with compound does very little because usually the seats are pitted..
Old 12-11-2014, 02:43 PM   #5
a-bone newby
Default Re: motors
tom my a has no shims and 2.5 thou clearance don't drive it much so probably ok doesnt burn oil and would like to know what compression test should be
Old 12-11-2014, 02:50 PM   #6
DJ S
DJ S's Avatar
Default Re: motors
2.5 thousandths clearance is quite a bit. Compression should be 76 and all cylinders should be within 5.
DJ S is offline   Reply With Quote
Old 12-11-2014, 02:50 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
Default Re: motors
~75 psig @ sea level... I'm told.
Old 12-11-2014, 06:03 PM   #8
Tom Wesenberg
Default Re: motors
My stock engine has 50 lbs on each cylinder and has good power. .0025" is borderline on what you should do. If you do short local drives, you'll probably get by OK for quite a while. If you want to put on lots of miles and go on trips, it would be best to have new babbit and shims.
BTW with .003" clearance on a newer Ford V8 I can hear the rods.
