Old 11-14-2014, 05:16 PM   #1
V8COOPMAN
V8COOPMAN's Avatar
Default Re: fuel consumption idleing?
I believe FrankW has trans-posted his forums. The car is a '33 4 cylinder. He seems to be having a problem finding a good troubleshooting method.
FrankW........Over on the V8 Forum, you noted this morning that you added more fuel.......should not be a fuel quantity problem.
After being given lots of good advice, you FINALLY checked to see if you had any SPARK. You finally alluded to the "NO SPARK" result. Not sure why you'd come over to the Model A Forum and request fuel quantity info again, especially on a '33. You really need to be more clear and organized with your symptoms and other info if the 'Barn folks are going to be able to help you. This is at least the second time you've moved or re-started a thread on this subject. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-16-2014, 08:59 AM   #2
FrankWest
FrankWest's Avatar
At 65 years old I never thought I would be bullied!
Did you attend PS 116 in Queens in 1961? Yout sound just like the kid that bullied me back then. I will not post again....., I will not use this forum
Excuseme for just being excited about my car...I should have known better an kept my excitement to myself.
FrankWest is offline   Reply With Quote
