I know most guys blast their rusty wire wheels, just wondering if anyone has come up with a dipping process for rust/paint removal?
would think a big drum could be cut down, a liquid added and put one wheel in at a time to soak for however long and a clean wheel might emerge? |
28-29?....or 30-31?.........it makes a difference..
As posted several times, you can soak them in Vinegar and it will take evey bit of rust off.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup 1931 Coupe 2 Smith Motor Compressors 1951 Ford F1 High Desert Model A's |
I used electrolysis on my Cub Cadet wheel. It took two days and did an excellent job on very deep rust.
As Dudley points out: the risky dipping, IMHO, would be the 28-9 rim. I used Les schwab's service several years ago. $57 to demount, send out, powder coat, remount and balance.
Nothing wrong with media blasting for me, even when I did it myself. repainting was much more work than the blasting if the neighbors don't complain, just do it outside. |
#6 | |
To remove rust, you need Phosphoric Acid. This process is known as Pickling ...and can be searched as such. Do not worry about soaking 21" Model-A wheels. If anything, this is a good thing. If you are concerned, drill a 1/8" hole in the bead to allow the mixture of Phosphoric & water to fill the bead cavity. When you drain it, use a propane torch to slightly warm the wheel rim which will evaporate the water. Use a welder to seal the hole --or just leave it open. (Won't hurt a thing!) |
Terry, how much time would it take to remove power coating from a wheel soaking in Sodium Hydroxide? Thanks
Model A Ford Club of New Jersey http://www.mafcnj.org Model A Pick Up Owners and Enthusiasts https://www.fordbarn.com/forum/group.php?groupid=5 |
It takes a couple of days to soften it where the steam cleaner can blast it off.
What is sodium hydroxide. Where do you get it?
very good-thanks fellas for the input!!!
I found out the hard way that antifreeze can remove powdercoating from inside the lower water pipe. A couple days after installing the pipe, chunks of black powdercoating were laying in the top tank of the radiator.
#12 | |
![]() Quote:
Here's just one "How To" video; http://youtu.be/y4yYF8gSHdA There is a lot of info on rust removal using electrolysis on the net. IMO Sodium Hydroxide (NaOH) is too dangerous to use in a uncontrolled environment (Home use). It is a strong alkaline compound (very high pH) used in industry. It can and will burn you much the same way an acid will burn you. Sodium Hydroxide is also used in drain cleaner. Last edited by Y-Blockhead; 11-15-2014 at 11:44 AM. |
#13 |
I would be cautious of the electrolysis method on wire wheels. I've used the process on a lot of sheet metal and frame components. I thought it would work well on 16" KH wire wheels which it did clean paint and rust very well. The one thing I did notice was that every wheel would have a couple of "broken spokes" afterwards. I think the process stresses high tensile components as the wheels did not show broken spokes prior to the dip.
Just my thoughts and experiences on wheels, I've had no issues with later 16" V8 disc wheels. Paul J. |
#14 |
Yes, I've wondered about hydrogen embrittlement, or any such problems, so for spoked wheels I guess I'd stick to sandblasting.
#15 |
Some of the spokes probably have stress already from past abuse.
The rims are usually out of true and that is from abuse. FTC. Les schwab, or media blasting are perfectly acceptable ways to go, or I would not have suggested them from my own experience. They are alot less trouble than engineering a chemical alternative. You decide. Bob |
#16 |
Les Schwab seems to be a North Western place. Closest to me would be ~300 miles north... but media blasting appears to be the way to go, for wheels anyway.
