Old 10-16-2014, 03:44 PM   #1
Timbo
Timbo's Avatar
Default First time A owner...Help!
Hello, I traded my '57 Plymouth for a 1930 Ford Tudor. I've never had a Model A but have always wanted one. I've only had the car a few days and already know I'll have it the rest of my life, I love it! I'll post pictures as soon as time permits. The only knowledge I have of Model A's is from this site and watching videos on YouTube.
The car drove home great and I started it a few times but now it won't start. I find that at the points and at the red wire off the coil with the ignition on I only have 2 volts. Now I assume it should be 6 volts but don't know. Could this be a problem?
Thanks, I'll be seeing you soon on here!
Timbo is offline   Reply With Quote
Old 10-16-2014, 04:17 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: First time A owner...Help!
Welcome! I am no electrical expert and I am sure Tom will chime in eventually. But assuming you have a good battery and a good ground (That is a must), it may be a bad coil.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-16-2014, 04:30 PM   #3
Mitch//pa
it depends if the points are open or closed... you will read 6v when the points are open and lose voltage closed. a common issue is oxidized points which you can clean with a file or such and regap..
opening and closing the points manually should create a little spark at the points contacts and also a spark from the coil wire @ 1/4 " from a head nut when the points are operated ///key on..
the moral of the story is ck and see if you have spark at the coil wire. if not clean and gap the points, also make sure the distributor cam turns when cranking the engine.
Old 10-16-2014, 04:34 PM   #4
Mitch//pa
oh i forgot and welcome to the club
youll like your A better
Old 10-16-2014, 10:49 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
The red wire goes to the switch and then to the points, so this is the ground wire and you should show 0 volts with the key on and points closed, as Mitch said.
Since you show 2 volts, that tells me the points contacts must need to be cleaned. A couple strokes with a points file or fine sandpaper should work.
If you have an original popout switch with the original wire, it could also be the original wire is partially shorting to ground, and thus the 2 volt reading. Hold the points open and see if you still show 2 volts. If you do, then the wire or switch is at fault.
Old 12-09-2014, 06:30 PM   #6
Timbo
Timbo's Avatar
Thanks guys for the information it was a great learning experience trying to get the car started. I did get it started after a few days under the hood. I now know all about the electrical system and timing. My problem however was not ignition related. My problem was that the car was out of gas!
Old 12-09-2014, 06:34 PM   #7
1930artdeco
Well...uh that will do it. Glad you fixed it and are enjoying the car again.
Mike
1957 Country Sedan
Old 12-09-2014, 07:05 PM   #8
C26Pinelake
Welcome aboard !
The expert has spoken. A good piece of advice is pay attention to what Tom tells you. He knows what he speaks of. Always great to have an expert in your corner. Wayne
Wayne
C26Pinelake is offline   Reply With Quote
Old 12-09-2014, 08:21 PM   #9
700rpm
700rpm's Avatar
Spark, compression, timing, and FUEL are all that you need to start the car. Welcome to the greatest hobby ever.
Ray Horton, Portland, OR
Old 12-09-2014, 08:41 PM   #10
loubob
Timbo;
Welcome to the Barn.
Also in ref. to your recent problem: Been there-Done that.
Loubob
loubob is offline   Reply With Quote
Old 12-09-2014, 08:49 PM   #11
ericr
ericr's Avatar
sounds like the gas gauge float is petrified.
ericr is offline   Reply With Quote
Old 12-09-2014, 11:51 PM   #12
jwaldrich
jwaldrich's Avatar
"No one can make me feel as stupid as I can".
I'm new to A's but semi T proficient. The learning fun and experience never ends.
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
Old 12-10-2014, 08:33 AM   #13
oldwoodsman
oldwoodsman's Avatar
Welcome Timbo. This is a great place to learn from a bunch of helpful people. Sounds like you're learning about the fuel system too
oldwoodsman is offline   Reply With Quote
Old 12-10-2014, 04:35 PM   #14
newshirt
newshirt's Avatar
Rrrr Rrrr Rrrr Rrrr
Ray White
newshirt is offline   Reply With Quote
Old 12-10-2014, 11:22 PM   #15
Ted in MN
Welcome to the hobby!
Be certain to disconnect the battery before working on your gas gauge. Any spark will be memorable.
Ted in MN is offline   Reply With Quote
Old 12-11-2014, 11:51 AM   #16
cdlwingnut
In a few years we will be seeing posts that say "please help, i had the model A plugged in all night and it still wont go"
cdlwingnut is offline   Reply With Quote
Old 12-11-2014, 01:30 PM   #17
Big hammer
Wecome to the barn! First time A owner! I to am a first time A owner, purchased in 1970 :-) still have it! Lots of good people here with know how, I learned from school of hard luck and still learning!
Old 12-11-2014, 02:27 PM   #18
29Cabriolet
29Cabriolet's Avatar
Originally Posted by loubob View Post
Timbo;
Loubob
Ditto
This was the first run out after removing and repairing the tank. But in the process, since most everything had to be removed from the firewall to allow the removal of the tank, I replaced many ignition parts and wiring. That's why my first suspicion of the problem was ignition. (That's my story and I'm sticking too it!)
29Cabriolet is offline   Reply With Quote
Old 12-12-2014, 05:14 PM   #19
180 a
Good Trade !!!!!
180 a is offline   Reply With Quote
Old 12-12-2014, 06:47 PM   #20
armchair67
Welcome! I'm a relative Newbie also. What model 57 Plymouth? I do live the 57-8 Fury and Belvedere! Love my 31 Tudor also.
armchair67 is offline   Reply With Quote
