Old 06-24-2014, 02:51 PM   #1
Brooks
Brooks's Avatar
Smile '40 flathead engine noise
My v8 flathead engine is making a pecking noise when it get hot. was rebuild about 200miles ago sit for 9 mos. while I restored my car. the motor is a stock 1940 v8. run good until it get hot driving it then running about 50 mph making the pecking noise. No noise at idle. Anyone had this problem or know what it could be. Also has good vacuum 21 at idle and all plugs are firing good. Have a Blessed Day!
Brooks is offline   Reply With Quote
Old 06-24-2014, 03:15 PM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: '40 flathead engine noise
How is the oil pressure, on the road and hot idle? Walt
Old 06-24-2014, 04:00 PM   #3
Brooks
Brooks's Avatar
Walt, The oil pressure is good 50lbs cold ilder about 25 to 30 hot, ilder at 20 hot. Thanks.
Old 06-24-2014, 05:32 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
If you havent already, try going up to speed and when the noise starts push it up in neutral and see if the noise continues while coasting with engine at idle.That would rule out a driveline noise. I had a simular problen once and found thet when the engine got hot the dome of the pistons on the right bank was just barely bumping the head. But that engine did had a pair of Offenhouser aluminum heads on it. The noise it made was a little heavier than a pecking noise.
Old 06-24-2014, 05:52 PM   #5
flatjack9
flatjack9's Avatar
Exhaust leak?
Old 06-24-2014, 07:47 PM   #6
35 coupe
35 coupe's Avatar
I had a similar thing in my 50 f1, would make a ticking noise at certain speeds, could not find it and then one day out it started and my speedo cable broke and the noise went away, put a new cable in, lubed the speedo, and no more noise. the noise was pretty loud, like a lifter ticking in the cab
35 coupe is offline   Reply With Quote
Old 06-24-2014, 08:15 PM   #7
Brooks
Brooks's Avatar
Ken, the noise is in the engine on the right side I believe in #3 cyl. I had a pertronic dist on it and found that #3 cyl was not firing above 500 RPM. I took the plug out it had lot of carbon on it. Could it be carbon on top of piston? If it is what is best way to clean it out? Thanks
Old 06-25-2014, 09:44 AM   #8
TomO
Seafoam will clean the carbon out of the cylinders.
TomO
TomO is offline   Reply With Quote
Old 06-25-2014, 11:46 AM   #9
charles in east texas
charles in east texas's Avatar
At fast idle slowly pour a 16 oz. bottle of MMO into the carburator, right before
The bottle is empty quickly pour the rest of the MMO in, probably will kill the engine.
Next turn off the key and wait 24 hours. That's what I did and got rid of my noise
That sounded like an insert. Also good for mosquito control. Charles
charles in east texas is offline   Reply With Quote
Old 06-25-2014, 12:40 PM   #10
Ken/Alabama
Once you get it firing on all 8 do as TomO suggested then take it out and run it hard for a mile or two.
Old 06-25-2014, 01:45 PM   #11
AnthonyG
AnthonyG's Avatar
MMO is the ticket for loosening / cleaning off the carbon. Have a '67 442 and years ago when I first got it (1983 ) it was high mileage and I knew it was loaded up with carbon. Did exactly what Charles said except went with two 16 ounce bottles and purposely stalled it with excessive dump at the end of the second ( definitely killed a lot of mosquitos ) Mine sat for a couple of days and ran a lot better. I was amazed at how clean piston tops and valves were when I finally rebuilt it several yrs later.
Go MMO
Nomad
AnthonyG is offline   Reply With Quote
