Old 06-19-2014, 01:16 PM   #1
TDO
TDO's Avatar
Default Air filter for Model A
Has any one used this Air filter on there model A . That's on E-Bay for $67.80. And what is your opinion of it.
http://www.ebay.com/itm/Ford-Model-A...-/160908017894?
TDO is offline   Reply With Quote
Old 06-19-2014, 01:21 PM   #2
silversink
silversink's Avatar
Default Re: Air filter for Model A
overpriced-----look at it---its 2 pipe fittings and a hose piece and a catalog filter--make your own.
Hotrods don't have valve covers
silversink is offline   Reply With Quote
Old 06-19-2014, 01:28 PM   #3
gweilbaker
gweilbaker's Avatar
Is that the filter that defies the laws of physics by working on "un-balanced" vented carbs? It does look cool.
gweilbaker is offline   Reply With Quote
Old 06-19-2014, 01:46 PM   #4
Charlie Stephens
Excellent idea if you plan to drive off road across the desert. At the rate I use my Model A and the roads I drive on it will outlive me so I think I will skip the filter.
Charlie Stephens
Charlie Stephens is online now   Reply With Quote
Old 06-19-2014, 02:04 PM   #5
vermontboy
Back in the sixties when some of us were driving these as our only vehicles (commuted every weekend from Rochester NY to Utica NY going to college) I don't ever recall seeing an air filter on any of them except for one show winner who had an original Air-Maze on his for shows.
Or is my memory poor ?? Mine had a stainless flex tube between the breather pipe and the carb, but outside of that I just don't recall seeing them. Nor do I ever recall lack of an air filter being a problem, although I suppose the dust and dirt could shorten the life of bearings and rings.
vermontboy is offline   Reply With Quote
Old 06-19-2014, 02:14 PM   #6
Gold Digger
I've got an oil bath air cleaner off an old hay baler engine that I put on my 2-door 29 back 43 years ago and works fine but have always wondered if it has the right balance of air. Didn't know about those things back when. I did worry about sucking the oil out of it when I would get up to 70 mph but never had that problem either.
Gold Digger is offline   Reply With Quote
Old 06-19-2014, 02:21 PM   #7
Purdy Swoft
Purdy Swoft's Avatar
I'm not a believer in air filters on model A's with updraft carbs. They mostly cause rich operation and cause more problems than they solve. Thats just me though. If you like it, go for it
Old 06-19-2014, 02:49 PM   #8
darrylkmc
darrylkmc's Avatar
The last thing that I would want is Gasoline drenched ABS plastic that close to my exhaust.
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 06-19-2014, 04:53 PM   #9
TDO
TDO's Avatar
My thoughts were the same as ya all. Thanks for your opinion.
Old 06-19-2014, 08:47 PM   #10
Growley bear
K&N air filter, the best filtration with the least restriction. Buy it once; according to K&N service every 50,000 miles. I service mine a little sooner. I am running a K&N on the air maze 90 degree adapter on a Zenith 2. Works great.
Chet
Growley bear is offline   Reply With Quote
Old 06-19-2014, 09:05 PM   #11
Jerry in Shasta
Jerry in Shasta's Avatar
One our club members has one he will give away. It will not stay on the carb.
The unit is too heavy and comes loose from the carb. when you hit a bump.
It is held on the carb. by a hose clamp and short piece of radiator hose, that's all. You get a little oil or gas on the joint and you can't keep it on.
JB
Jerry in Shasta is offline   Reply With Quote
Old 06-19-2014, 09:06 PM   #12
160B
160B's Avatar
I use a K&N E-3050 air filter in an original Airmaze. I have one on my 1931 160B for 30,000 plus miles and also have one on my 1931 68B for 3,000 plus miles. The filter does not cause the engine to run rich and makes a significant improvement on keeping the engine oil cleaner over time. I used to change oil every 500 miles and it was dark and dirty, now I change oil based on color and usually change oil at 1,000 miles or even 1500 miles.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 06-19-2014, 10:01 PM   #13
eagle
eagle's Avatar
I use an original AirMaze and have no ill performance effects. I drive dusty gravel roads all the time and don't want that grit traveling through my engine.
Old 06-19-2014, 10:13 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
The oil wetted mesh should grab a lot of dust and not cause any noticeable restriction.
Old 06-20-2014, 12:06 AM   #15
Willie Krash
Willie Krash's Avatar
I use a K&N and have had no problems.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 06-20-2014, 12:36 PM   #16
Bruce
Bruce's Avatar
I use the "overpriced" High Boy. Bought it on eBay. Cost was cheap when compared to my spare time to play with Model A's ... and I work for free! Add in the gas and wear and tear on my truck to drive to and from Menards and I'm money ahead. I like Rich Falluca and I've given him a small fortune for a couple really good running engines, but I do not want to write another check to AER for a long time. If keeping dirt from being sucked into the carb might keep me away from Skokie a little longer, the filter is a "no brainer," even if Henry didn't think they were necessary.
Bruce is offline   Reply With Quote
Old 06-20-2014, 12:40 PM   #17
mshmodela
mshmodela's Avatar
Darryl in Fairbanks
Agreed. If I drove on mostly dirty roads I might consider
http://www.snydersantiqueauto.com/5431
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 06-20-2014, 02:45 PM   #18
JOES31
JOES31's Avatar
If you are using a filter with the downdraft carbs I would only consider using a filter that is above the carburetor. If you have a small leak and it accumulates into the filter then you have a dangerous hazard with it right next to the exhaust.
If it couldn't be above the carb then I would go without. My opinion.
Joe
JOES31 is offline   Reply With Quote
Old 06-20-2014, 04:31 PM   #19
Barber31
Barber31's Avatar
Just bought the filter that "U's" back under the carb. Suppose to be hi flow filter. I haven't received it yet so I'll see how the fit and finish goes.
Barber31 is offline   Reply With Quote
Old 06-20-2014, 04:34 PM   #20
FrankWest
FrankWest's Avatar
Out of the showroom I thought these 4 cylinder fords had no air filters.
Wasn't the first airfilter introduced on the v8?
I am so confused
FrankWest is offline   Reply With Quote
