Working on my hood. What do you guys use to grease the hood hinges? Thanks as always!
I oil mine.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
Mine get sprayed with WD40 when I clean the underside.
A drop or two at each joint. Work hinge a few times. Wipe off any excess.
Ditto
#7 | |
![]() Quote:
I use teflon spray.
AFTER YOU PAINT IT! Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
Many years ago I got a bunch of teflon rod pieces from a friend that ran screw machines.I made maybe a half dozen center hood rods out of them,and I don't think I've ever looked at one of them since.They're quiet,smooth,and no rust works it's way out of the hinges with use.I still used the metal rods in the hood side joints,as I never found any scrap teflon rods that small.I don't believe I've ever lubed one after it was installed either.
The first thing that I do is replace the steel hood hinge rods with stainless steel. Most vendor have them, they don't rust and need no oil.
Yeah, what Purdy said.
#13 |
With door hinges the oil draws down with use and gravity, seems like a lot of use to get the oil to travel sideways an inch, I suppose if the hood is removed you can oil the hinges on the backside seam.
#14 |
I use graphite it doesn't collect dust like oil does.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls '41 Fordor Deluxe / 2-duece flattie '66 1/2 Dodge Charger '14 100th Anniversary Challenger Limited Edition. Semper Fidelis ![]() |
#15 |
#16 | |
![]() Quote:
Yeah, like Purdy, I've used same stainless rods for years..very nice to have NO rust, eh ![]() BTW..do not get mine from vendors, perse, but from builder discount/supply places. They also have rods in diff metals (brass is good too). Last edited by hardtimes; 02-27-2014 at 02:54 PM. Reason: ......... |
