Old 01-04-2014, 11:03 PM   #1
sidhartha
sidhartha's Avatar
Default Changing the steering wheel in a 31 Tudor
I am changing the steering wheel in my Tudor. Any tips tricks or advice before I start? I think I need to drop the column but not sure how much or if I need a special puller.
sidhartha is offline   Reply With Quote
Old 01-05-2014, 09:54 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Changing the steering wheel in a 31 Tudor
Remove the tank clamp and the two bolts mounting the steering to the frame. Hopefully this will give you enough drop to remove the light switch rod. You might need a special puller for the steering wheel, as some are stuck very tight. DO NOT hammer on the threads.
Old 01-10-2014, 09:00 AM   #3
sidhartha
sidhartha's Avatar
I've looked in my catalogs and the puller looks to straight forward and simple. I'd like to make my own. Anyone know the dimensions I'll need for a 31 Tudor?
Old 01-10-2014, 10:31 PM   #4
DougVieyra
DougVieyra's Avatar
I am also wanting to change the Steering Wheel on my '31 Coupe. As both the Coupe and the Tudor are closed cars, would there be any difference in the process between the Tudor and a Coupe ?
As the Coupe has less room to manuvuer than a Tudor, will the smaller, constricted space of a Coupe create a problem that would not be an issue with the more spacious interior of the Tudor ?
DougVieyra is offline   Reply With Quote
Old 01-10-2014, 11:13 PM   #5
Tom Wesenberg
I'd bet on the coupe you need to completely remove the column, but only lower it on the Tudor.
Old 01-11-2014, 12:06 AM   #6
700rpm
700rpm's Avatar
Tom's right, as usual. You have to remove the column from a coupe, unless you have a roll down back window.
Ray Horton, Portland, OR
Old 01-11-2014, 01:43 AM   #7
Dave Mellor NJ
Or you can remove the fixed window.
Dave Mellor NJ is offline   Reply With Quote
