Old 12-13-2013, 11:48 PM   #16
bdave_mcc
bdave_mcc's Avatar
Default Re: new model A owner, modification questions
Originally Posted by garyaodell View Post
You mention oil leaks; before you do anything, allow the oil level to drop to half way between the full and low marks on the dip stick, also make sure the breather cap is not sealing the crankcase. I had a bad leak when I first got my coupe, it turned out to be the bell housing casket was on reversed allowing the cam shaft bearing to be open to atmosphere. these engines do not have rear seals so they do drip a little.
Ok guys, had some time today to get the A out and tool around a little.its been parked at my in laws since I got it. Here's what I found. The clutch shaking wasn't really a big deal. However the oil leak is awful. But seems like the p.o. Was trying to keep the oil level on full. The oil breather was clear, no pressure. I'm hoping when it gets down some it'll lessen...the wife was pissed about the driveway when I got home lol. But did have a bit of a surprise. There were no problems with running, but I was taking a close look at everything once getting back I noticed I had water coming from a crack in the block. I guess I'm going to have to get out the JB weld...the pictures are within 10 minutes of parking.
Got a little work to do to figure out the oil leak but in the meantime, is there a way to search for members by location on here? I'm really wanting to find other A owners and possibly someone who can do babbit or rebuilds in my area. Birmingham, al
bdave_mcc is offline   Reply With Quote
