Old 11-20-2013, 07:23 PM   #1
howie123
howie123's Avatar
Default Re: Speedster Kit
The deck for the Rootleib kit is made of 2 layers of 3/4 inch plywood. The top layer is one large piece, the bottom layer is smaller pieces placed for reinforcement. I am not sure of the sheet metal thickness. It is quite easily formed over the cowl and around the seats. In the kit, the hood is about 3 inches longer than stock and so the firewall is about 3 inches further back. That requires moving the steering column back. It also means changing the choke rod, starter rod, throttle and spark linkage. If you are not using the kit, you can do whatever you'd like. I saw a picture of a speedster built using a stock cowl and fenders and it looked really nice. You can be as creative as you want and that is the fun part. Howie
howie123 is offline   Reply With Quote
