#21 |
happened to me solved by turning lights off
#22 |
thanks all for your ideas and particularly for the wiring diagrams. Looks like I have my work cut our for me. Being a widower I'm awaiting my son to stop over and lend me a hand (hard to be at two places under/around the car at one time). Weird thing is that it didn't occur until after I'd driven it a couple of times. I'll keep y'all posted on the results. Again, thanks!
#23 |
Then you'd be sucking the juice out of the bulbs instead of putting it in?
#24 |
fixed ended up being problem at light switch thanks for all the posts
#25 |
Congratulations on the fix, and thanks for the report.
#26 |
If you look at the wiring diagram the bale receives its power from a wire from the generator cut-out (or alternator). The wire is attached to a buss inside the bale. Attached to same buss is a wire that runs to the brake light switch. There is really no reason for power to the brake light switch to be routed through the bale. A better idea is to remove the wire from the bale to the brake light switch and instead run a wire from the fuse holder (or the starter switch connection if you don't have a fuse) direct to the brake light switch. With this set up there is less chance of losing power to the brake lights and trouble shooting the brake light circuit becomes very simple. Should you be out on the road and you have a short circuit in any of the wires in the bale and it blows the fuse (or starts a fire if you don't have a fuse) you can disconnect the wire from the generator (alternator) to the bale and eliminate the fault and still have brake lights. If it is daytime you can continue to drive the car safely with functioning brake lights until you are able to trouble shoot the bale. Tom Endy |
