Great testing..
Not to Hijack but as people are looking I just ordered the Bob Drake water pumps for mine, Are they similar to Skips? I cant remember seeing anything about removing thermostats?
"Came too close to dying to stop living now!" |
#2 | |
![]() Quote:
The design of Skip's impeller is what is known as a mixed-flow design that can move more volume with less pressure than the other pumps that are centrifugal design that create more pressure to push through restrictions. It's a bit of an anomaly in my opinion for some to taught Skip's pumps as high volume when they are only such if you remove the thermostats which, if you do, makes any pump high volume. Since it is so important to have thermostats keeping the engine above minimum operating temperature both in hot and cold weather it doesn't make any sense to me to sacrifice the benefit of thermostats just to get more flow from a pump that is no higher volume with thermostats than any other pump. Hope that makes sense. Much more discussion on the difference between Skip's pumps and others here: https://www.fordbarn.com/forum/showthread.php?t=106054
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
