Old 06-08-2013, 03:33 PM   #1
160B
160B's Avatar
Default Re: testing jets
Originally Posted by redmodelt View Post
RE: 2. the length of the hole.
Please expand on that in relationship to the jets in a Model A carburetor.
Original jets are a certain length, but the inside diameter is not the same over the entire length.
At the tip of the jet there is an orifice, smaller diameter sized to deliver the correct amount of fluid. This orifice is say 1/32” long at say a # 63 drill size.
Now when you solder the tip closed you cannot control the amount of solder that flows into the tip of the jet. So let’s say after soldering you now have to drill a # 63 size hole through let’s say 3/32” length of solder. This jet now has the same size orifice of # 63 drill but since the orifice is now 3/32" long the flow will be reduced.
Also the entrance into the orifice is not the same gentle curve due to the results of soldering, so this will also reduce the flow because you have changed the entrance characteristics of the orifice.
I will upload photos when I resolve a missing security token that does not allow me to upload photos
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 06-08-2013, 03:49 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Ryan wrote this a few years ago;
Are you getting a "Security Token Error?"
If so, please excuse it... It's a bug. Typically you get that error when uploading images. It just means that the images you are uploading are too large in file size.
Old 06-08-2013, 04:19 PM   #3
160B
160B's Avatar
Thanks for the input Mike V. Florida
Original jets
Soldered jets
Last edited by 160B; 06-08-2013 at 04:35 PM. Reason: aded Thanks for the input Mike V. Florida
Old 06-08-2013, 04:34 PM   #4
Pinstripe
Excellent information Thanks
Pinstripe is offline   Reply With Quote
Old 06-08-2013, 06:00 PM   #5
Sparky
Sparky's Avatar
Here's my tester. It's hard to se on the picture but there is a submersible pump in the water reservoir. There is a smaller supply tank inside the large one that supplies the water to the jets. The pump keeps the level of the water in the supply reservoir constant; the excess water overflows into the catch tank and gets recirculated.
Sparky is offline   Reply With Quote
