Old 02-11-2013, 01:32 PM   #1
PetesPonies
PetesPonies's Avatar
Default Re: My new Model A pickup
I'm referring to the red spots on the back of the cab.
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 02-11-2013, 02:03 PM   #2
George Miller
George Miller's Avatar
Yes I did, maybe it was not a good idea. It had some bad rust Pitts from laying on it side for years, before it went to the barn. The gas tank was about half full of mud from laying on it's side. As luck would have it, I had a better tank.
George Miller is offline   Reply With Quote
Old 02-11-2013, 02:47 PM   #3
PetesPonies
No one should be using that material anymore. It swells from whatever you put on top of it and it will shrink as it dries out. It causes sand swell scratches to occur after its painted. There are 2K finishing putties that you should use and throw that stuff away
Pete's Ponies
Old 04-04-2013, 04:14 PM   #4
George Miller
Default Re: My new Model A pickup, update
Cab and hood painted. now for the fenders and splash aprons.
Old 04-04-2013, 06:16 PM   #5
Mikeinnj
Mikeinnj's Avatar
Nice paint job George ! What color is it and what kind of paint was used ? Single stage, CC/BC ??? Enjoy !
Mikeinnj is offline   Reply With Quote
Old 04-04-2013, 07:33 PM   #6
George Miller
It is a blue from 2010 Impala. The paint is Masons Acrylic Enamel with hardener.
Old 04-04-2013, 07:25 PM   #7
Vanspeed
Vanspeed's Avatar
Nice color, I like it big time.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 06-13-2013, 12:54 PM   #8
George Miller
Up date
Just the fenders and interior left.
Old 06-13-2013, 01:37 PM   #9
Tim/Va.
Looks like mine. I think I used Niagra Blue.
Tim/Va. is offline   Reply With Quote
Old 07-20-2013, 08:03 AM   #10
George Miller
Here is the truck now. The out side is just about done. Still need some head light parts.
Old 07-20-2013, 08:47 AM   #11
jhowes
You must be getting tired of questions but, I have an engine that has sat out like yours how did you free up the pistons etc. No penetration solution seems to touch mine. The pistons are stuck and who knows what else. Jack
jhowes is offline   Reply With Quote
Old 07-20-2013, 03:16 PM   #12
George Miller
In my case I was going to bore the cylinders any way. So I just busted the pistons out. The cylinder walls were pitted bad. Took 3/16 of a inch to clean them up.
If your engine is not to bad, use some kind of penetrating oil in the cylinders. In the past I made a tool out of a old starter, put a nut on the shaft, bolted in place of the starter. Then turned it with a big wrench. That broke it loose.
Old 07-20-2013, 09:24 AM   #13
1931 flamingo
1931 flamingo's Avatar
Try a 50/50 mix of ATF and Acetone, pour it into the cyls, let soak, repeat. FWIW
Paul in CT
Old 07-20-2013, 10:39 AM   #14
mass A man
mass A man's Avatar
George, Just want to give you a thumbs up!
mass A man is offline   Reply With Quote
Old 07-20-2013, 03:35 PM   #15
scbill
Are you going to do anything to the frame for strength? I just bought a 1930 closed cab last month. First problem was shearing an axle key as the castle nuts were too loose! Has Hydraulic brakes from a 1946 Ford pickup.
scbill is offline   Reply With Quote
Old 07-21-2013, 01:25 PM   #16
Itchy-Pit
Itchy-Pit's Avatar
Nice read. How's she drive? Farthest you've gone?
Itchy-Pit is offline   Reply With Quote
Old 07-21-2013, 09:37 PM   #17
George Miller
To the end of the drive way.
Old 08-15-2013, 02:24 PM   #18
flatheadz-forever
Are you able to post videos of it driving? very cool build nice work
flatheadz-forever is offline   Reply With Quote
Old 08-15-2013, 03:07 PM   #19
George Miller
I might get my Son to take some videos when diving it. But right now it is Title time. So got to get that done first.
I'm also working on the upholstery now. That is not my kind of work.
Old 08-15-2013, 04:27 PM   #20
mndodge
Great looking truck!!
mndodge is offline   Reply With Quote
