Old 06-11-2012, 05:14 AM   #1
CountrySquire55
CountrySquire55's Avatar
Default Re: Installing emergency brake return springs
Here is what I did before installing the rear brake drums. For installing the emergency brake lever springs (there is a left and right spring), once all the emergency brake parts are on the car, do not yet connect the emergency brake connecting lever to the emergency brake toggle lever. This will give you about 3/4" more rearward movement of the toggle lever which makes all the difference. Lying under the car, I then used a tack removal tool (similar to a flat screwdriver with a notch cut in the end) to push the hook of the emergency brake spring over the toggle lever. With the extra 3/4" to work with, installing the spring takes about 10 seconds. Then, with the spring installed, you can easily pry the connecting lever to align with the hole on the toggle lever and install the connecting pin, cotter pin, and then install the drum. I have no problem removing or installing the springs but this method requires the rear drums to be off the car.
CountrySquire55 is offline   Reply With Quote
