Old 02-24-2012, 03:16 PM   #1
William Kelchner
William Kelchner's Avatar
Default New Guy
Hello, just joined the forum which appears to be a treasure trove of information. I own a 30 Roadster and a 64 Impala convertible.
Bought the Model A years ago and been fiddling with it ever since--had overheating problem among other problems. To date I've installed a new radiator, fixed the speedo, new speedo cable, replaced the small gear at the transmission to accept the new cable, new water pump, new exhaust, has hydra brakes, new carb (Zenith), replaced the radiator shroud with one I found at Carlisle, Pa. auto show for $40 (had two minor cracks at the bottom and no dings, the cracks are completely hidden by the stone guard - could not believe the luck in finding this buried in a pile of parts.
Now the overheating appears to be under control. I just installed new plugs and retimed the machine. The only thing I cannot fix is after cruising around it backfires one time about 10 seconds after turning off the ignition. If I run the carb dry no backfire. I presume this is a rich condition but I've tried everything with the carb without success.
Any suggestions. Thanks Bill
William Kelchner is offline   Reply With Quote
Old 02-24-2012, 03:19 PM   #2
Gary WA
Gary WA's Avatar
Default Re: New Guy
Check for cracked manifold or leaking gasket (manifold). Good luck keep us posted.
www.whidbeymodelaclub.com
Old 02-24-2012, 03:38 PM   #3
William Kelchner
Default Re: New Guy
Thanks - I'll give that a whirl.....cheers
Old 02-24-2012, 03:52 PM   #4
BashawT
Default Re: New Guy
Welcome to the forums
BashawT is offline   Reply With Quote
Old 02-24-2012, 04:38 PM   #5
William Kelchner
Default Re: New Guy
I presume we are talking about the intake manifold being cracked
or getting extra air?? Tnx
Old 02-24-2012, 08:02 PM   #6
Gary WA
Gary WA's Avatar
Default Re: New Guy
Exhaust manifold! especially where it curves down toward muffler connection,back side. Broken ear/bolt area or loose bolts.
Old 02-24-2012, 08:19 PM   #7
foxfire42
foxfire42's Avatar
Default Re: New Guy
If you have a 1930, how well did that shroud fit? The shroud was used on 28/29 style radiators not the taller 30/31's
AAhhhhhhhhhhhh, you call the raditor shell a shroud.....Sorry
foxfire42 is offline   Reply With Quote
Old 02-24-2012, 08:19 PM   #8
William Kelchner
Default Re: New Guy
Thanks, looks like tomorrows project....cheers
Old 02-24-2012, 08:28 PM   #9
VWJoe
VWJoe's Avatar
Default Re: New Guy
Welcome to the "Barn". I'm just up the road
VWJoe is offline   Reply With Quote
Old 02-24-2012, 08:33 PM   #10
joe plumber
Default Re: New Guy
Welcome .
joe plumber is offline   Reply With Quote
Old 02-24-2012, 08:34 PM   #11
TinCup
TinCup's Avatar
Default Re: New Guy
Take some wd 40 and spray around the intake and the carb and listen for it to be effected by the extra fuel.
TinCup is offline   Reply With Quote
Old 02-24-2012, 08:38 PM   #12
jcheshire31
jcheshire31's Avatar
Default Re: New Guy
Foxfire, I think what he means by "shroud" is actually the radiator shell since he said the stone guard hides the cracks.
jcheshire31 is offline   Reply With Quote
Old 02-24-2012, 09:37 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: New Guy
I turn the fuel off, then push the spark lever up, then turn the key off. This will slow the idle and you'll have less raw gas drawn into the engine, which might help your backfire problem.
Old 02-24-2012, 10:13 PM   #14
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
Default Re: New Guy
I'll second everything Tom Wesenberg said. If this doesn' help, you might try adjusting the float level just a tad. Of course that shouldn't be a problem if you follow Tom's advice about turning off the gas.
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 02-24-2012, 11:59 PM   #15
Leathernek
Leathernek's Avatar
Default Re: New Guy
Welcome to the "Barn!!!!"
"The Assistant to the Assistant of The Guru of Stuff"
Leathernek is offline   Reply With Quote
Old 02-25-2012, 12:25 AM   #16
Mike V. Florida
Mike V. Florida's Avatar
Default Re: New Guy
Welcome!
Sorry to hear about the Chevy
When my car did the same thing, backfiring, I went back through the the ingnition, checking the gaps on the dist, in the dist and went through the timing again. The problem went away.
I scared the hell out of my wife before I fixed the problem. I drove the car into the garage. Turned off the car by reaching in through the window, ran into the house and yelled duck, then the car backfired.
Old 02-25-2012, 10:30 AM   #17
William Kelchner
Default Re: New Guy
Thanks to everybody, with all these suggestions one of them has got to be the solution.
Old 02-25-2012, 05:51 PM   #18
William Kelchner
Default Re: New Guy
%@##&^ tried spraying WD-40 around the manifold and no noticeable change. One thing tht I have not addressed is that one of the small bolts that attach the intake to the exhaust manifold is broken off and the remaining portion of the bolt (threads) are still in the exhaust manifold. Sprayed around this area without success. Perhaps I should just remove the maifolds and fix this.
Old 02-25-2012, 08:35 PM   #19
1930artdeco
1930artdeco's Avatar
Default Re: New Guy
If you did not get any change around the manifold I bet it is a slightly rich condition in the muffler. It is storing extra gas then when it gets hot after the motor is shut off, bang.
That is my story and I am sticking to it By the way, welcome and how about pics of the car?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-25-2012, 09:49 PM   #20
John LaVoy
John LaVoy's Avatar
Default Re: New Guy
Welcome to the Model A hobby. I would suggest checking out a local chapter the members can be a great resource.
John LaVoy is offline   Reply With Quote
