Re: 1930 Hood Out of Alignment Just a Little.....
Hey Marco, thanks for checking in. My inspection indicates that both rear edges of the driver and passenger hood top pieces appear to have the same contours and both lay well on the cowl welting. However, the passengers side front lower corner lays about 3/8 of an inch forward of where it should. Then if I push the hood back to make the front of the hood fall onto the welting indent on the radiator shroud the rear right corner of the passenger hood top panel moves up off the cowl welting as does the rear side of the passenger hood bottom panel.
