Old 10-27-2025, 07:53 AM   #1
KMBeers
KMBeers's Avatar
Default Sector bushing removal question
I’m currently rebuilding my 7 tooth steering box and I’m looking for some advice on removing the old sector bushings. They are in a through bore and I’m wondering if the Bratton’s bushing installation tool can be used to push them both out at the same time from the same side. The 2 tooth box uses the same bushings so the same situation applies there too. If there’s a different trick it would be good to know before I try it.
KMBeers is offline   Reply With Quote
Old 10-27-2025, 10:00 AM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: Sector bushing removal question
I would imagine the tool would be capable of removing them and also installing them. I made my own tool. Here’s a video I made quite a few years ago on the seventh tooth doing all this with the steering box still in the car. Hopefully it might help you.
https://m.youtube.com/playlist?list=...1kpxH2TLliMjIX
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 10-27-2025, 04:49 PM   #3
Jim16A1
Those videos are very helpful. I’ll also be tightening up my 7 tooth in the near future.
Jim16A1 is offline   Reply With Quote
Old 10-27-2025, 05:42 PM   #4
katy
katy's Avatar
Bratton's says: "Use this handy tool to help remove and install the sector bushings in both 7 and 2 tooth steering boxes."
Old 10-27-2025, 06:12 PM   #5
KMBeers
KMBeers's Avatar
Thanks for the link and all of the videos. Very helpful on what needs to be done to get the sector shaft bushings out and the new ones installed. I am going to rebuild a new box I picked up at Hershey so it is already “out” of the car. Did your sector shaft just fit in without reaming or hoaning the new bushings? I could see if you used the old sector shaft that had a little wear reaming may not have been needed. Thanks again.
Old 10-28-2025, 11:28 AM   #6
Fullraceflathead
Yes once I press the bushings in the old sector shaft slid right in my sector shaft when I miked it was only worn a few tents but the bushings were obviously large enough I did not need to hone or ream them.
-Henry Ford
1941 Willy's Pickup
Old 10-28-2025, 06:20 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
I don’t know what they are selling now for sector bushings but is they don’t need reaming or honing I doubt the fit will be good for long,the bushings I was sold a while ago were AA kingpin bushings that the sector fit in without any fitting and the contact points were a very low percentage of the bushings surface area.
Old 10-29-2025, 08:43 AM   #8
Fullraceflathead
I remember I purchased them from Snyder's and I was wondering the same thing if they would need to be honed or reamed after installed they fit snug but definitely no tight spots and there was no looseness.
-Henry Ford
1941 Willy's Pickup
Old 11-02-2025, 08:19 PM   #9
old ugly
old ugly's Avatar
i have changed 7 tooth sector bushings (along with all the other parts in there) on three occasions. two of those 3 bushings needed to be honed a tiny bit to fit nice.
someone mentioned tightening up their 7 tooth. note, there is no adjustment on the 7 tooth box that will tighten it up. the only way to make it right is to start replacing parts.
the 2 tooth is a different story.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 11-06-2025, 06:36 AM   #10
Jim16A1
Yeah, by “tightening up” I meant that I would be dumping hundreds of dollars into parts and time with the machine shop, just to slap a band-aid on a poorly designed piece of technology. Also, there are some tolerances that can be adjusted via shims and the lash screw, so it technically doesn’t have “no adjustment” it is just a lost cause once things start to wear inside.
Old 11-06-2025, 07:57 AM   #11
jb-ob
My $.02, I find the seven tooth steering box much easier to rebuild satisfactorily than diddling with the later two tooth. Your mileage will vary.
jb-ob is offline   Reply With Quote
