Old 07-28-2025, 11:17 AM   #4
TJ
TJ's Avatar
Default Re: 1936 sedan sway question thoughts ideas???
If you used longer shackles you have answered your own question. That is your sway problem. You should use a dropped axle with stock shackles and a tube shock kit on front and rear. You can lower the rear by having a spring shop lower the arch of the spring. If you still have mechanical brakes the dropped axle will not work with them.
