Old 07-17-2025, 08:57 PM   #21
serocontra
serocontra's Avatar
Default Re: Floorboard
Originally Posted by BRENT in 10-uh-C View Post
Not sure what "not looking to win any shows..." has to do with doing something the correct way (-really doesn't matter if it is a Model-A or something else) but the easiest way to correct the misdrilled holes is to drill oversized and glue in a wood dowel to fill the hole. Use a #12 screw that fits the D-nut and cut to approximately 3/8 - 1/2 inch long. Insert the screw into a drill motor and spin while grinding one end to a sharp point. Then insert the screw with the point facing upward and when the floorboard is positioned correctly, push downward on the floorboard and the point will make a divot where the new hole is to be drilled.
Meaning I’m not going for stock awards, yet.
Very clever. I will employ that trick.
Archeo-Tech Priest of the Cult Mechanicus.
serocontra is offline   Reply With Quote
Old 07-18-2025, 05:22 PM   #22
Bullrhider
Bullrhider's Avatar
As I recall, Bonnie Parker (Bonnie and Clyde) was severely burned by battery acid from hip to ankle when she and Clyde were involved in a rollover accident. Not sure make or year of the car, but Clyde preferred Fords...
Bullrhider is offline   Reply With Quote
Old 07-18-2025, 06:30 PM   #23
Brentwood Bob
When replacing the floor boards I put threadstock in each clinch nut in the subframe. The top of the threadstock was ground to a sharp point. This located the hole to drill. Went one at a time.
Brentwood Bob is offline   Reply With Quote
Old 07-18-2025, 06:31 PM   #24
Brentwood Bob
When replacing the floor boards I put threadstock in each clinch nut in the subframe. The top of the threadstock was ground to a sharp point. This located the hole to drill. Went one at a time. I don’t believe there was a template to locate the holes at the factory.
Old 07-18-2025, 06:34 PM   #25
Brentwood Bob
Oops
Old 07-18-2025, 11:39 PM   #26
TomInCologne
TomInCologne's Avatar
sorry, i don't know (and google doesn't either) what threadstock means. Can you please send a photo?
TomInCologne is offline   Reply With Quote
Old 07-19-2025, 11:24 AM   #27
Y-Blockhead
Y-Blockhead's Avatar
Maybe he is referring to All Thread (threaded rod)? Similar to this; https://www.amazon.com/National-Hard...80&sr=8-5&th=1
Old 07-19-2025, 05:23 PM   #28
Brentwood Bob
Yep
Old 07-19-2025, 09:17 PM   #29
JayJay
Y-B, that's threaded 1/4-20. Wrong thread. You need threadstock in 12-24. If you try 1/4-20 it will go in a little way and then jam, bougering up the threads in the D-nuts. I did find this stuff on the river store https://www.amazon.com/Pieces-12-24x...57&sr=8-1&th=1 but that's a lot of stock for what you need it for. McMaster-Carr has it, pack of 10 @ 1" long https://www.mcmaster.com/95475A405/ or much cheaper to buy a 1 ft or 2 ft length.
Tom, for what shipping from the US would cost you might do better to find round stock in Germany (#12 is 5.556 mm diameter) and buy a 12-24 die, do it yourself.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 07-19-2025, 10:07 PM   #30
Y-Blockhead
That is why I said "similar". I didn't know the correct size thread, I was just using that as an example to explain what All Thread/Thread Stock looked like for TomInCologne... Geez, so picky!
Old 07-20-2025, 06:49 AM   #31
JayJay
That is why I said "similar". I didn't know the correct size thread, I was just using that as an example to explain what All Thread/Thread Stock looked like for TonInCologne... Geez, so picky!
Check.
JayJay
Old 07-21-2025, 02:16 AM   #32
TomInCologne
Thanks.
My floorboards fit, i was just curious what that word meant and then how to fit new holes.
