I am rewiring my 40 Ford and I see there is an ignition resistor on the board with circuit breaker and my question is do I now buy a non resistor coil?
Thanks for the help. |
You only need 1 resistor and yours is where you described. The coil won't make sparks if it gets less than 4 v.
Mike, the '40 Ford coil has no internal resistor. You need the dash mounted resistor for this coil, which will deliver 4 volts (target) to the coil. If you use an aftermarket coil, odds are it will have an internal resistor, in which case you simply bypass the dash mounted one.
I'm no electrical genius, but as i understand, the ballast resistor is smart, delivering close to 4 volts whether it receives the correct 6 volts or not. It does this by way of heating or cooling, heat in an electrical circuit is resistance in itself. Now, with that in mind, remember that the starter motor is greedy, grabbing lots of lightning away from the ignition circuit. This is why with some cars, you crank and crank, it won't start until the moment you release the starter. I f you experience this phenomenon, simply create a momentary resistor bypass from ignition switch directly to coil. Never run with this bypass, use it only to start the engine. More info than you asked for, but good to know for your rewiring project.
Alan |
Thanks guys,
I checked with my friend at the auto parts store and he said he can get me a Standard Products Co.non resistor coil for car,he said it should be good,very old company. Mike |
First of all, are we talking an original Ford-type coil that mounts right on top of the distributor or a modern "can-type" coil? Just make sure the coil itself is not "very old". They tend to deteriorate with age. At least test the primary and secondary windings for the proper resistance. (<10 ohms on the primary and more than 10,000 on the secondary.)
Alan |
I still believe the resistor is only used with the Ford coil up to 1948. 1949 to 55 never seen any resistor or Chevys Chrysler prod. etc. with the can coils. 12 volt systems yes
need a resistor. That goes for pos or neg ground. I run a can coil on my 46 no resisor no problem for 16 yrs daily driver... |
Are you changing to 12 volts or staying with 6 volts? Are you using the original style coil or a modern round can style coil ?
I neglected to say that I put a late model flathead in my car, after dealing with full floating bearings for sixty years I decided to treat myself to a modern engine! Ha Ha.A friend of mine scraped out a 50 Merc years ago and I grabbed the engine.
Thanks for responding. |
Now all you have to do is tell us if your car is still 6 volts or has been converted to 12 volts. Then perhaps we can begin to offer some useful advice.
Everything is still the stock 6volts,only the engine has changed,sorry.
Now that we have all the information, we can consider the original question.
I am rewiring my 40 Ford and I see there is an ignition resistor on the board with circuit breaker and my question is do I now buy a non resistor coil?" My advice, since you are essentially using an 8BA engine, is to bypass the '40 ignition circuitry completely and just run the ignition lead to the 8BA (or compatible) coil. 8BA's did not use a resistor coil. I believe a Bosch "Blue" coil from a Volkswagen is an acceptable substitute. |
#13 |
Thanks to everyone for all their input, will proceed with the project.
#14 | ||
![]() Quote:
A Bosch blue coil is a 12 volt coil with an internal resistor. It has been a while; but if I remember right the post '49 cars used a 6 volt coil an internal resistor. Guess you have a choice of a non-resistor 6 volt coil retaining the firewall mounted resistor or a internally resisted 6 volt coil and jump the firewall resistor. Might come down to a choice of which coil is available. If the one you chose comes from Mexico or China; maybe get two and carry the extra in your trunk. Quality of this stuff has really gone downhill; just saying. |
#15 |
Yes, it comes down to coil availability. The post '49 coils did not have a resistor. You want a coil with 1.5 ohms primary resistance. A straight replacement for a '49-'53 Ford would be best. Who knows, you may find a 6 volt Mallory "Best" coil that looks great and works well. In any event I would absolutely eliminate the original '40 resistor because you do not want to mix ignition types. The '40 ignition resistor works on a completely different principle than a modern ballast resistor.
Sorry about the mistake on the "Blue" thing. I do know there is a 6 volt Volkswagen replacement from Bosch that works. Last edited by tubman; 07-07-2025 at 02:22 PM. |
#16 |
I have found a Standard Products Co.non resistor coil that will work with my stock Forty Ford ignition resistor that is mounted behind the dash and he said that they are an old company known for quality parts,what do you guys think?
#17 |
The Mallory design components that Ford used on the V8 cars were specially made to fit with the distributors Ford used up through 1948. After that, Ford contracted with Holley to use the Load-O Matic design in conjunction with the 8BA and 885 carburetors made by Holley for Ford and Mercury respectively. The Mallory designs all needed a ballast to control the current to the coil for optimal performance and reliability. Straight 6-volts would be hard on them.
The can type coils with the 1.5 Ohm primary never needed current control so they work fine with 6-volt systems. The early 12-volt systems tried to get away with using the same 1.5 Ohm coil in 1956 but they were problematic to they added a ballast resistor to control the current on them or they would get too hot. Ford and other manufacturers did this clear up into the early electronic ignition era. The modern 3-Ohm primary coil was developed using new materials so it could work on 12-volts with no ballast control. Special epoxy mixtures replaced the oil in these new type coils so they can take the heat with no problems. |
#18 | |
![]() Quote:
Still, knowing the problems some have had with the resistors and their replacements, I would opt with a standard 8BA replacement coil wired directly (eliminating the resistor). Anytime you can reduce the number of components in a system, you are ahead of the game. Last edited by tubman; 07-07-2025 at 10:47 PM. |
#19 |
I didn’t want to use the load-o-matic distributor so I bought a new Mallory duel point which is on the engine now.All I’m trying to do is use the wiring harness that I bought from Dennis Carpenter in the stock configuration.
The only reason I made the changes was because it was a 60 horse and just too wimpy! |
#20 | |
![]() Quote:
Your 40 resistor has two terminals, an in and an out. Just connect your "out" wire (going to the coil) to the in terminal together with the "in" wire from the ignition switch. This bypasses the resistor. Then follow the good advice from Tubman in the last paragraph of #18. |
