Old 06-21-2025, 09:48 AM   #1
DENY 411
Default amp reads backward?
car was sitting for 2 yrs. Now it starts and runs , The amp meter shows adischard when engine is running. When swich is off turn rhe lights on and it shows a charge. Not a discharge. I am confused!
DENY 411 is offline   Reply With Quote
Old 06-21-2025, 09:53 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: amp reads backward?
How is the battery connected? — originally the car is positive ground.
If it was and the battery is put in negative ground the ammeter will work backwards
Old 06-21-2025, 10:14 AM   #3
DENY 411
The battery is correct. As car was sitting 3 people were working on it at the same time,
not sure what all was done to it! IT does start and run, and the amp meter used to work correctly.
Old 06-21-2025, 10:50 AM   #4
Ruth
Sounds like someone switched the wires when "working" on the dash.
Ruth
Old 06-21-2025, 11:01 AM   #5
Gene F
Gene F's Avatar
If the battey in it positive to ground, then just swap the wires on the amp mete - problem solved.
Old 06-21-2025, 11:06 AM   #6
nkaminar
nkaminar's Avatar
If your electrical system is using positrons instead of electrons then the meter will read backwards.
Old 06-22-2025, 10:09 AM   #7
DENY 411
update:thankyoukurt in NJ Ruth, and Gene F--I pulled IP amp meter was not touched the Ing swich was wires had been swiched (Not orininal style) I swiched them back making sure not to let it short out agin. Everything fine!
