Old 06-19-2025, 09:38 PM   #1
2speed
Default Re: Aluminum foil around gas line?
So where is specifically seems to boil is between the needle valve and the gas line?
With the needle closed, pressure would build to not let gas flow, but when the fuel is sucked up the venturi, the needle would open, relieving the pressure? Or does the boiling gas create bubbles that lift the float not allowing it to open? Isn't the bowl vented to atmosphere?
2speed is offline   Reply With Quote
