Old 07-03-2012, 02:26 PM   #1
bob p
Default Ames bodied model T
I just bought a 1922 Model t. I think it has the Ames body. Higher and wider radiator shell, California type top, Completely different body, and all six removable side windowss. wider body, rear gas tank, fancy interior. Amost 100% complete and rust and dent free. Many of these around? It has been sitting in a barn for the last 40 years. Any one have pictures, Thanks, Bob
bob p is offline   Reply With Quote
Old 07-03-2012, 04:58 PM   #2
jackdaron
Default Re: Ames bodied model T
Can you post pictures?
jackdaron is offline   Reply With Quote
Old 07-03-2012, 08:06 PM   #3
jackdaron
Bob sent me pictures. Interesting,but I'm not sure what it is. It is and aftermarket body of unknown manufacture. I did forward pictures to Dan Treace who is good at finding these things,so we'll see.
Old 07-05-2012, 03:27 PM   #4
tmodelman
Would agree that this T appears to be an Ames built body.
While Ames is mostly associated with speedsters, they did build other bodies for Ts.
One clue is the dashboard, most higher end aftermarket builders, National, Dayton, etc had a finished firewall built in the body. The Ames were made to fit to the Ford chassis, so you see the existing Ford wood firewall, to which the Ames body is fastened. An that cowl vent door, somethings Ames did. Front mud guard, rounded body cowl, and use of std. Ford fenders, aprons and running boards. A body built to sit on the Ford chassis.
The radiator shell is higher to use the Ford radiator, many other builders used special high radiators with their high straight line body styles. An used 'hidden hinges' in the body doors, that was high end practice. Note the Ames, being a lower-cost builder, used exposed hinges on the doors.
The top on this Ames seems original, so this is perhaps the Tour-Sedan model. Never have seen one, you did see speedsters. That Tour-Sedan would be quite rare.
tmodelman is offline   Reply With Quote
Old 07-05-2012, 03:33 PM   #5
tmodelman
Meant to re-post the pics Jack emailes me of Bob's new T..."Ames Tour-Sedan"
So here they are:
Old 07-05-2012, 04:09 PM   #6
jackdaron
Thanks Dan.
Old 05-16-2025, 08:04 PM   #7
rrhoover
rrhoover's Avatar
i know this is old post but i believe i am the current owner of this AMES BODIED model T
rrhoover is offline   Reply With Quote
Old 05-16-2025, 11:09 PM   #8
J Franklin
J Franklin's Avatar
rrhoover, now it is your turn to post some photos. I always liked any Model T.
Old 05-31-2025, 09:11 AM   #9
rrhoover
rrhoover's Avatar
here a current pictures of the AMES .
it needs to go to someone to preserve it instead of going into my barn to deteriorate until my estate sale.
it will be very reasonably price.
car is complete and good condition and should run easily.
Old 05-31-2025, 10:18 AM   #10
rotorwrench
rotorwrench's Avatar
I'm glad you posted those photos since it shows the window inserts and interior. That was quite a set up and it deserves to be known by model T folks even though it isn't all Ford.
Old 06-02-2025, 06:55 PM   #11
mercman from oz
mercman from oz's Avatar
Old 06-02-2025, 06:57 PM   #12
mercman from oz
Old 06-26-2025, 07:05 PM   #13
351cmach
I believe a buddy of mine just bought this car. I can't wait to check it out.
351cmach is offline   Reply With Quote
