Yeah or nay on loctite on the main bearing bolts on a Burtz block? Blue loctite that is....
Ask Mr.Burtz.That way it comes from the source,and not a dozen guys telling their opinions and how their grandaddies did it for years.
I use Loctite on every bolt & nut even when using lock washers with the exception of head bolts that need re-torquing.
Ask Terry.
Blue (Medium strength) Loctite applied to clean threads is a good choice.
The threads on the head studs that screw into the cylinder block should have anti-seize, and the head nuts should have nothing on them. |
This has nothing to do with the model As but it is food for thought. Helicopters are currently required to have two locking features on all control system linkage hardware. Many use a locking castle nut with a cotter pin and some use a locking nut with safety wire. The Robinson types used steel locking nuts with a pall nut. That always reminds me of my late Mercury 8CM flatheads V8s that used a pall nut on the connecting rod nuts. They likely didn't need them but I always put them back on there during an overhaul. Last edited by rotorwrench; 05-19-2025 at 10:21 AM. |
NAY!
I never use loctite on any rod bolt or (especially) main bearing main cap!! no exceptions!
"My Model A... work never ends, only the day ends!" |
#8 | |
![]() Quote:
#9 | |
![]() Quote:
Sounds like a belt and suspenders situation.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 05-19-2025 at 09:08 AM. Reason: Correction |
If you have no bum to speak of, it takes what ever it takes to keep your pants up. I state from experience.
#13 |
#14 |
Thanks for asking...
as a mechanical fastener locking enhancer... can it hurt? Loctite Blue? probably not. but, no need for any thread locker on engine rod bolts or main cap bolts. they are designed to stay put... with torque setting loads as designed! and they will and do! ![]() hope this helps. to me, my comment is beyond just an opinion.
#15 |
furthermore... from minds bit smarter than mine.... AI:
AI Overview No, Loctite blue is generally not recommended for engine main cap fasteners. Main cap fasteners are designed to be torqued to a specific value to ensure proper clamping force and bearing support. Applying threadlocker like blue Loctite can interfere with the intended clamping action and potentially lead to issues like bearing damage or fastener loosening.
#16 |
Anything that remains in liquid state when applying torque to a high torque fastener will increase the bind on the threads at the proper torque as a thread lube would do. Some fasteners can't use any form of thread lube or it will damage (stretch) the threads. I always go by the manufacturer's recommendations. Terry is that so go by his recommendations on his product.
#17 |
