Old 03-17-2025, 11:01 AM   #1
psimet
psimet's Avatar
Default Stuck oil seal retainer - steering lower bearing assembly
7-tooth steering box. I have it pulled apart and cleaning it and I can not remove the nut- oil seal retainer in the steering lower bearing assembly.
The plate with the 4 hold for the mounting bolts is loose enough it can rotate a bit so if I clamp up on it - just spins the central body of the assembly.
I tried using something in the oil hole to try and hold the body but it still spins out of a vise.
Any tips for loosening it? I don’t feel like buying a new assembly for $100+
psimet is offline   Reply With Quote
Old 03-17-2025, 10:18 PM   #2
psimet
psimet's Avatar
Default Re: Stuck oil seal retainer - steering lower bearing assembly
Got it done. Used a hex wrench in it tonight. The felt packing was essentially gone and the retaining nut had been tightened hard against the base.
Also re-staked the plate on the assembly. You can see the small dots in the last photo.
