Old 03-03-2025, 04:29 PM   #35
34 fordor owner
34 fordor owner's Avatar
Default Re: Chasing same issues again any ideas? ‘34
Originally Posted by rockfla View Post
Just an "aside" here BUT have you checked your battery with a Hydrometer to see IF all three cells are good??? You can have a low or bad cell and still get a 6 + Volt reading with a multi meter BUT you will have a tremendous loss of amps as well as cold cranking amps!!! SO make sure you have a good strong battery with three good cells
Just installed a new battery and resistor a week ago, working on points and getting fresh plugs. It has 6 volt at the coil points close 3 open. Tried starting and it’s right there has a little get up like it wants to crank then go back to normal crank sound. Maybe it is the plugs so points and plugs. Running autolite 386.
34 fordor owner is offline   Reply With Quote
