Has anyone found any seals that will seal the side glass [Mod-A] from water?
Maybe from a later mod. car or ??? |
Between the door and glass? Water was to go down door and drain at door bottom thru drain holes.like this?
www.whidbeymodelaclub.com |
I understand this, I am a 81 year old body man and I would like to seal the big gap up a little as on the later models. I am looking for seals that will fit on the outside. Maybe screw to the door shell, as on later cars.
The Model "A" came with dust seals but no water seals. The seals in my 45-B Coupe looked the seal in the sketch.
Bob Bidonde |
Is there enough room to fit maybe a modern wiper blade to seal the glass???
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
Most of these were there to minimize water intrusion but some are more effective than others. |
My 31 Sport Coupe has a rubber seal but they were on it when I bought the car. The man who installed them is dead and I don't know what he used. I will try to get a picture later.
TOB |
McMaster Car has a number of rubber extrusions. One may work.
Glue fuzzy home sliding door seals from the hardware store to the window lower channel.
Or to the outside skin window sill. The slant window cars have a special rubber extrusion from the vendors that probably can be used on other models but requires removing the glass. The seal only works with the glass fully in the up position and is more of an air seal than water seal. |
You can find a rubber glass lower bedding with a lip to stop water. It was used on other makes, maybe GM cars. Ford sedans used a metal channel with a squeegee rubber screwed to the door wood to close the gap and I think coupes had somthing similar (photo post #2). Keep looking.
https://www.snydersantiqueauto.com/p...7750&cat=41680
There are/should be weep holes in lower inner skin to let water escape. Model A doors are far from tight…all four sides pretty open. Last edited by Oldbluoval; 02-07-2025 at 08:02 AM. |
55 years ago after washing my A I could here water sloshing around in the doors, I removed the upholstery cleaned out the mud and cleaned out the drain holes. When I would wash it I made sure to run the garden hose down past the glass making sure water ran out of the drain holes. The quarter window upholstery was a pain though, my panels where made of water resistant material
#13 |
Here is the seal on my Sport Coupe. Like I stated in post #7 the previous owner (RIP) installed these and I don't know where he got them or what they were designed for but they fit perfectly.
