Old 02-05-2025, 08:35 PM   #1
boggie
Default Side Window Water Seal
Has anyone found any seals that will seal the side glass [Mod-A] from water?
Maybe from a later mod. car or ???
boggie is offline   Reply With Quote
Old 02-05-2025, 08:58 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Side Window Water Seal
Between the door and glass? Water was to go down door and drain at door bottom thru drain holes.like this?
www.whidbeymodelaclub.com
Old 02-05-2025, 09:16 PM   #3
boggie
I understand this, I am a 81 year old body man and I would like to seal the big gap up a little as on the later models. I am looking for seals that will fit on the outside. Maybe screw to the door shell, as on later cars.
Old 02-06-2025, 09:31 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
The Model "A" came with dust seals but no water seals. The seals in my 45-B Coupe looked the seal in the sketch.
Bob Bidonde
Old 02-06-2025, 11:35 AM   #5
Fullraceflathead
Fullraceflathead's Avatar
Is there enough room to fit maybe a modern wiper blade to seal the glass???
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-06-2025, 11:52 AM   #6
rotorwrench
rotorwrench's Avatar
I've not seen any door glass wiper seals for model As. A person would have to research wiper seals from later cars that might work with the door edge to glass interface. Reproduction ones are available from repro parts sources for later Fords and some GM products. Attatchment to the lip might be the governing factor as well as distance from lip to glass.
Most of these were there to minimize water intrusion but some are more effective than others.
Old 02-06-2025, 02:46 PM   #7
TerryO
TerryO's Avatar
My 31 Sport Coupe has a rubber seal but they were on it when I bought the car. The man who installed them is dead and I don't know what he used. I will try to get a picture later.
TOB
TerryO is offline   Reply With Quote
Old 02-06-2025, 03:45 PM   #8
nkaminar
nkaminar's Avatar
McMaster Car has a number of rubber extrusions. One may work.
Old 02-07-2025, 12:35 AM   #9
SAXBY2
Glue fuzzy home sliding door seals from the hardware store to the window lower channel.
Or to the outside skin window sill. The slant window cars have a special rubber extrusion from the vendors that probably can be used on other models but requires removing the glass. The seal only works with the glass fully in the up position and is more of an air seal than water seal.
SAXBY2 is offline   Reply With Quote
Old 02-07-2025, 02:08 AM   #10
J Franklin
J Franklin's Avatar
You can find a rubber glass lower bedding with a lip to stop water. It was used on other makes, maybe GM cars. Ford sedans used a metal channel with a squeegee rubber screwed to the door wood to close the gap and I think coupes had somthing similar (photo post #2). Keep looking.
Old 02-07-2025, 07:50 AM   #11
Oldbluoval
Oldbluoval's Avatar
https://www.snydersantiqueauto.com/p...7750&cat=41680
There are/should be weep holes in lower inner skin to let water escape.
Model A doors are far from tight…all four sides pretty open.
Old 02-07-2025, 08:03 AM   #12
Big hammer
55 years ago after washing my A I could here water sloshing around in the doors, I removed the upholstery cleaned out the mud and cleaned out the drain holes. When I would wash it I made sure to run the garden hose down past the glass making sure water ran out of the drain holes. The quarter window upholstery was a pain though, my panels where made of water resistant material
get a bigger hammer tap done
Old 02-09-2025, 09:20 PM   #13
TerryO
TerryO's Avatar
Here is the seal on my Sport Coupe. Like I stated in post #7 the previous owner (RIP) installed these and I don't know where he got them or what they were designed for but they fit perfectly.
