I have what I believe is called a "Timken Split Axle differential. Here is the carrier. After the water drained out, no oil to be seen, I found the bearings rusty, unsure about inside the differential. I would like to rebuild with new bearings, but don't know where to obtain specs, instructions, etc. Any pointers?
IMG_7700.jpg IMG_7701.jpg IMG_7699.jpg |
Get a shop manual reprint, step by step directions. And contact Chuck Mantiglia of Chucks Trucks. He will have all the bearings, gaskets and seals you will need.
I dig coal, which provides motivation for EVs. |
I have been looking for something called a Shop Manual, and could only find a 32-41 Ford/Mercury Service Manual... although it called itself a shop manual. Has no instructions for rebuild, only general service. What book are you referring to?
I just got a box of goodies from Chuck for my front axle, which is the same Timken 51524 as the rear.
Pictured is the pile of pinion bearings. There is one called the pinion pilot bearing. That will need to be replaced, even if not rusty. Mine looked good, but the race was pitted. If that fails, it will most likely ruin your axle. You can see its home in the picture.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 01-27-2025 at 04:03 PM. |
Chucks contact info
Ford had a special tool for pulling pinion assembly. I made one from a 6 “ square of 1/2” plate and some all thread. Some tension on the allthread and some propane heat, and out it popped.
Chuck is great to deal with. Good prices, great advice. He knows these old Ford trucks. If you have the standard 4.86:1 ratio, and want something less steep, he has kits to put 4.11.1 ratio in that axle.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 01-27-2025 at 07:37 PM. |
I also have the carrier bearings and races, as well as the king pin bearings. The carrier races can be tricky getting out of the housing, I just welded a bead along the inside of race. After it cooled, it popped out no problem.
In the process of doing a final cleaning of the inside and getting the whole works set up on bench for assembly. Most likely you will need a press to insert pinion assembly into housing when you get to that point.
I just called and Chuck was super helpful, Thanks!
No further responses to this thread, as I am NOT going to attempt this job ![]() |
I do need a complete Kingpin set though. I think PN 78-3111
That is a question for Chuck. Being 4wd, I have tapered roller bearings top and bottom on each side.
#13 |
If you can locate a copy of this shop manual it will be helpful in working on your truck. Crank en Hope went out of business but it looks like these folks are selling it. https://www.themotorbookstore.com/19...op-manual.html.
#14 |
just bought on eBay, thanks!
#15 |
I know you said you weren’t going to tackle this, but I would suggest getting a gallon of Rust 911. It is pricey per gallon, but one gallon makes 16 of solution. If you don’t have a bead blaster, you will find this stuff invaluable. Not bad, and it is effective. If you have a way to keep container warm, so much the better. Drop the differential carrier in the solution and leave it alone for awhile. At least you will see what you have after rinsing it off.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 01-28-2025 at 11:35 AM. |
#16 |
My pinion puller, if you can imagine all-thread with a nut and large washer resting against plate on the bottom side. The pinion yoke nut is taken off, yoke removed, then plate out into place and pinion nut tightened against it. Then tighten nuts on all thread, both ends of all thread are set on pinion flange. My test mule required no heat, the front axle wanted some. Ive made all sorts of pullers to meet my needs. Stubborn stuff requires high strength all-thread from McMaster Carr. These were accomplished with hardware store offerings.
You don’t need to invest in high dollar, high fallutin’ Ford tools to do this. As a farm kid who grew up learning the much maligned “farmer fiixes”; with the help of this site, the HAMB, Chuck, and FTE, I do all right.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 01-29-2025 at 07:44 AM. |
#17 |
Almost forgot a shout out to YouTube. Made a new battery tray with hand tools. A planishing hammer made from an old leaf spring helped to smooth it out. Had fun in the process
Taught myself how to correctly restore carburetors with plating and chromate finishes. Don’t know your skill set, but curiousity goes a long ways…
#18 |
Chuck's is about the only support for R&P sets for the Timken Detroit axles. Some of the later units are impossible to find new parts for. Good used is as good as those get. Timken bearings should be available. Seals may have to be matched but there are still some Chicago Rawhide seals around. A person just needs the part numbers.
The transmission should be a T8 or T9 4-speed. Ford used them for years. They aren't synchronized so a lot of folks don't like them. There are a lot of them out there, Some Folks convert the rear end to a Dana 60 or other truck type axle just to get better ratios. Last edited by rotorwrench; 01-29-2025 at 06:00 PM. |
