Old 01-12-2025, 05:51 AM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default 53 Mercury 4bbl air cleaner
What is the diameter of the opening that fits over the carb on a stock 53 4bbl air cleaner? Thanks. Reply to [email protected] please.
Tim Carlig
dean333 is offline   Reply With Quote
Old 01-12-2025, 09:45 AM   #2
pistonbroke
Default Re: 53 Mercury 4bbl air cleaner
Ive never seen a 53 merc 4V. Hmmm.?
Old 01-12-2025, 10:03 AM   #3
Merc Cruzer
Merc Cruzer's Avatar
The opening for a stock 53' Mercury 2 bbl air cleaner is 4 3/4"
Merc Cruzer is offline   Reply With Quote
Old 01-12-2025, 11:14 AM   #4
dean333
dean333's Avatar
I believe the stock 4bbl option was a Holley 2140.
Tim Carlig
Old 01-12-2025, 11:34 AM   #5
Merc Cruzer
The 4 bbl was first used on the Mercury's, on the 54' "Y" block.
Old 01-12-2025, 12:39 PM   #6
scicala
scicala's Avatar
Respectfully, it is 5 1/8". Ford products never used the 4 3/4" neck on any carburetor, other than the '56 Mercury with a Carter WCFB four barrel and the '57 LIncoln with the same Carter. GM and Chrysler did though.
In '53 Mercury used a 1901 Holley 2 barrel teapot with a 5 1/8" neck.
In '54 Mercury used a 2140 4 barrel teapot also with a 5 1/8"neck.
Sal
scicala is offline   Reply With Quote
Old 01-12-2025, 12:41 PM   #7
scicala
scicala's Avatar
In '54 the 2140 wasn't optional. It was the only carb offered in all US built Mercruy's.
Sal
Old 01-12-2025, 01:04 PM   #8
tubman
tubman's Avatar
If the O/P is actually referring to a 4 BBL on a '53 Mercury, it has to be an aftermarket setup. The old 4 BBL manifolds took the old "square" pattern carburetors. These were made by Holley, Carter, Rochester, and even Stromberg. I just measured a small-base 4G and it is 4 1/8". I have a Stromberg "Aeroquad" I can measure later if anyone cares.
Old 01-12-2025, 03:47 PM   #9
Merc Cruzer
Sal
I measured the opening, in the bottom of the stock, 53' Mercury air cleaner, with the stock 1901 Holley 2 barrel teapot, and it is 4 3/4". The outer frame opening, for the carburetor, is
5 5/8"
Old 01-12-2025, 04:07 PM   #10
jimTN
Show us a picture of this 53 with a magical 4 br
Old 01-12-2025, 05:28 PM   #11
scicala
scicala's Avatar
5 5/8"
Yes, I was referring to the mounting surface on the carb, and not the air cleaner. My mistake. I just measured a '53 Merc 1901 that I have for parts, and it's 5 1/8" diameter the the center of the air cleaner gasket surface on the carb.
Sal
