Old 12-27-2024, 01:57 AM   #1
expavr
expavr's Avatar
Default Re: Unmolested 40/41 1 Ton pickup?
Originally Posted by 52flthed View Post
Expavr. that is one beautiful truck! . I like the Hall back up lamp you have. Is that the one that says FORD on it? What did you use as a switch for it? I have two of those on my bumper as well. Show us some pictures of your dash if you can please? What other accessories do you have on the truck?
To answer your question about accessories I took some liberties with the Tonner that don't exactly fall into the definition of an accessory, but they made operating it a whole lot more usable and roadworthy.
The backup light is a "Yankee" found at a swap meet.
Its triggered by a switch mounted on a bracket that holds an early 4 speed trans shift tower mounted on a 49 Merc O/D transmission which I'm using in the Tonner. (photos 1 and 2)
The dash light and Southwind heater were accessories on the truck when I bought it. Both work. The Southwind heater too well... (photos 3 and 4)
After running the truck for a couple of years on the Firestone polyester tires I had a set of OEM 17" rims modified and installed 16" Michelin all weather radials. The spare is a 7:50 - 17 Firestone which was the OEM tire. (photo 5)
The bed wood is Apiton a hardwood like teak that gets a Tung oil wipe down annually. When the disassembled plywood bed liner is in place the Tonner becomes a hauler again. (photo 6 and 7)
How its being used now is a far cry from 1940 when it hauled 50# bags of wheat seed on a wheat ranch in Eastern Washington, but its not a trailer queen either and gets put to use as the need arises.
expavr is offline   Reply With Quote
