Old 11-18-2024, 12:15 PM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Radiator Support Rods
I learned the hard way (idiot dues, 2024) not to crank the radiator using the two support rods to correct the hood alignment. The bracket attaching the rods to the radiator broke lose! The subject radiator is a reproduction, and like the original radiator, the bracket was soldered to the upper tank. The solder failed. Also, the bracket had some damage, so it is time to replace it. Fortunately, a new bracket is available from Synder's, and it is an excellent match of the original. A fellow Model A'er is coming over to solder-on the new bracket.
My lesson learned is that the radiator hoses need to be very lose and the rods disconnected to realign the hood. Also, drain a gallon of coolant out before loosening the hoses. The rods retain the radiator's position once it is positioned to your liking.
Bob Bidonde
Old 11-18-2024, 06:28 PM   #2
marty in Ohio
marty in Ohio's Avatar
Default Re: Radiator Support Rods
My bracket broke off a few years ago. Our local radiator shop soldered it back on quickly. It wasn't cheap but it got me back on the road.
Marty
marty in Ohio is offline   Reply With Quote
Old 11-19-2024, 12:06 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
My original radiator has the bracket both rivited and soldered .
Old 11-19-2024, 12:00 PM   #4
mass A man
mass A man's Avatar
I have an older "Berg's" radiator in my pickup, the bracket seems to be riveted and soldered. Thanks for the heads up Bob.
mass A man is offline   Reply With Quote
