Old 10-31-2024, 06:28 AM   #1
Steves46
Steves46's Avatar
Default Terminal Box Connection Question
Good morning. Are washers needed between individual terminal lug connections in the Terminal Box?
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 10-31-2024, 08:45 AM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Terminal Box Connection Question
No. Stack all the wire terminals on top of each other, put a washer on top of all of them, and then a nut that is tightened.
Jim Cannon
"Spread the Joy! Have a Model A day!"
Old 10-31-2024, 09:01 AM   #3
Tom F OHIO
Tom F OHIO's Avatar
Does anyone have a good picture or drawing showing which wires go where??
Thanks.....
Tom F OHIO is offline   Reply With Quote
Old 10-31-2024, 09:13 AM   #4
The Master Cylinder
The Master Cylinder's Avatar
Thanks.....
https://www.fordgarage.com/pages/awiringdiagram.htm
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 10-31-2024, 12:39 PM   #5
Steves46
Steves46's Avatar
Thanks Jim.
Old 10-31-2024, 02:23 PM   #6
Tom F OHIO
Tom F OHIO's Avatar
Originally Posted by The Master Cylinder View Post
Thanks TMC
Old 10-31-2024, 02:28 PM   #7
Tom Endy
Tom Endy's Avatar
Reproduction terminal blocks can short out. Attached article is how to prevent that.
https://www.santaanitaas.org/wp-cont...l-Block-TE.pdf
Tom Endy
Old 11-01-2024, 09:13 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
This excellent article by Alex Janke should help you:
https://sacramentocapitolas.org/wp-c...alex-janke.pdf
Bob Bidonde
Old 11-01-2024, 05:03 PM   #9
Tom F OHIO
Tom F OHIO's Avatar
Great site Bob, thanks alot...
Old 11-02-2024, 11:17 AM   #10
katy
katy's Avatar
Put a lock washer between the nut and the flat washer, or use a nylock nut.
Old 11-03-2024, 09:08 AM   #11
Jim/GA
Jim/GA's Avatar
TRUE!
I use little "star washers".
I forgot that, since the question was about flat washers between the wire terminals.
Thanks for adding that.
Jim Cannon
