Old 08-19-2024, 08:40 AM   #1
CatMan1
Default The Wind Or The Carb
We took our '28 Sport Coupe to the Model A Day in the Amanas this weekend. It's 82 miles one way. It did really good going there. I did notice what I thought was wind gusts blowing us around or maybe just pushing the wind since the car isn't very aerodynamic. Does anyone else feel the wind when driving these? However when we went to leave I had to really crank on it to get it to start. Like it wasn't getting any gas. When we stopped for fuel it wouldn't stay idling unless I really revved it up. We almost couldn't get going, but I kept up-shifting and got it into high and we made it home. I'm suspecting the carb needs cleaned or rebuilt. It has the pencil screen in the tank and the one at the sediment bulb. Maybe what I thought was the wind in the morning was the carb causing it to surge? It also tends to backfire through the exhaust. Thoughts? (We had planned to clean the points, but ran out of time.)
CatMan1 is offline   Reply With Quote
Old 08-19-2024, 09:07 AM   #2
Will N
Will N's Avatar
Default Re: The Wind Or The Carb
What was the temperature on your way home? Was it hot? Sounds like you could have been experiencing vapor lock.
Will N is offline   Reply With Quote
Old 08-19-2024, 09:22 AM   #3
Rob Doe
Wind is definitely a factor, especially a strong cross wind that is gusting. Backfire through the exhaust is usually a rich mixture. Sometimes a novice will mistake an exhaust leak for a backfire.
A backfire through the exhaust is sometimes referred to as an after-fire. A backfire through the carburetor is referred to as a backfire to delineate between the two. The backfire through the carb is a lean condition.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 08-19-2024, 09:24 AM   #4
Rob Doe
Cleaning and setting the point gap would be the first place to start.
Old 08-19-2024, 09:28 AM   #5
JayJay
I definitely feel wind, especially at highway speed when running close to max what the car will do. Of course, a headwind going out can turn into a tailwind coming home…
I’d also start with points before tearing into the carburetor. I’ve had similar symptoms as yours that were resolved by regapping.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 08-19-2024, 09:41 AM   #6
Fullraceflathead
Fullraceflathead's Avatar
If the points don't look very good at all you might try changing the condenser.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 08-19-2024, 09:46 AM   #7
CatMan1
It was a warm day....around 80. The symptoms got worse after I filled up. The station only had Ethanol as an option so I wonder if that was a bad idea.....
Old 08-19-2024, 09:47 AM   #8
CatMan1
It's definitely after-fire, then.
Old 08-19-2024, 09:48 AM   #9
CatMan1
I'll for sure be checking the points. I've had the car for three years and I don't recall ever having replaced them.
Old 08-19-2024, 04:02 PM   #10
JayJay
Be careful on replacing. Some of the aftermarket points had the arm the wrong length and they don't line up with the point block properly. The vendors sell a special point block that resolves this issue for those points.
See the note attached to Snyder's part number A-12160-X. Best bet is to order new points and block at the same time even if you don't think you need to replace the block.
JayJay
Old 08-19-2024, 05:26 PM   #11
ModelA29
ModelA29's Avatar
A carb guru told me when troubleshooting he finds a lot of owners "fuel" problems are electrical in nature. If the spark isn't right it's not going to run right......
ModelA29 is offline   Reply With Quote
Old 08-19-2024, 05:30 PM   #12
Big hammer
Check the points first, clean and set the gap before changing parts, you’ll save time and money !
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 08-20-2024, 10:07 AM   #13
Will N
Will N's Avatar
When you stop the engine (or even come to a prolonged stop, like at a red light), the lack of airflow through the engine bay allows the heat to soak the carb and fuel lines, making the symptoms of vapor lock even worse. Gotta get moving to get the airflow to cool the carb.
Old 08-21-2024, 03:07 PM   #14
gdmn852
gdmn852's Avatar
Hello, if the problem started after the ethanol, I might suspect that being the cause, I try to avoid ethanol if possible, some time have no choice. As far as feeling the wind , yes it’s noticeable, cars of this era are as aerodynamic as a brick.
gdmn852 is offline   Reply With Quote
Old 08-21-2024, 05:54 PM   #15
David in San Antonio
David in San Antonio's Avatar
Re: aerodynamics - Buckminster Fuller claimed that conventional sedans (shaped like the Model A) had so much aerodynamic drag they were more efficient running backwards rather than forwards. He then went off the deep end, designing the Dymaxion automobile with a teardrop shaped body on a tricycle chassis with two front driving wheels and one rear wheel which steered like a rudder. Oh, and the engine was in the rear with a drive shaft to power the front, non-steering axle. He built three prototypes. The aerodynamics made them very fast. The rear-only steering allowed them to turn 360 degrees in their own length, but was treacherous to drive. You can read a modern test drive in the Car & Driver archives. Maybe it’s on the web.
Late ‘30 Deluxe "Wretched Roadster"
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 08-22-2024, 06:45 AM   #16
Bob Bidonde
Bob Bidonde's Avatar
I once drove my Model A Coupe from Baltimore to New York in a hurricane. The Coupe ran fine in the high winds and driving rain. Moreover two semi trucks kept me between them all the up I-95 and the water spray the front truck kicked-up had no effect on the motor, but the spray made vision out of the windshield difficult. I had a CB radio back then and the truckers made surrounding traffic aware my Coupe was between them. I love those caring truckers!
Bob Bidonde
