05-01-2024, 08:23 PM | #1 |
39 door lock. Drill out hardened screw
So I had to drill out the hardened screw that held the door lock in. I used a TN coated carbide ball nose endmill in my battery drill and took my time and mostly kept it centered. Then I tapped the hole to 1/4-28 and made an insert from a piece of 1/4” tube that I threaded 1/4-28 on the outside and also drilled and taped to 10-24 on the inside. (I was going to do 8-32 but the hole in the tube was too big for that so I went up a size. If I were to make it from solid stock and center drill it then I would try for 8-32). I then coated the 1/4-28 threads with loctite 609 and screwed it in. When it dried run a 10-24 tap onto it to clean out any loctite that got into the 10-24 hole and it’s ready for the lock and new screw.
Good to know I went with the 10-24 because that’s what I had and it worked with the tube I had. If I had 10-32 I could have used it. With the tube being 1/4” There is not much left after the inside and outside are threaded. So for more strength cutting it 8-32 would leave more metal in the repair but it seems it’s not needed my repair is working the lock is in and the screw is tight. I just used an ordinary cap screw with an Allen head.
I am building a 1939 1 ton express Last edited by ActionYobbo; 05-03-2024 at 11:54 AM. |
05-01-2024, 10:24 PM | #2 |
Re: 39 door lock. Drill out hardened screw
Sounds like a great repair!
05-02-2024, 09:05 AM | #3 |
I posted how I did it so it might help some one in the future.
I am building a 1939 1 ton express |
05-02-2024, 10:07 AM | #4 |
Good job. That's a tedious repair that requires the patience of a toothache.
Well done. |
05-02-2024, 11:49 PM | #5 |
Using a TN coated carbide ball nose endmill to carefully drill out the screw and then tapping the hole to 1/4-28 to create a new threaded insert demonstrates your skill and ingenuity. Additionally, fabricating an insert from a piece of 1/4" tube, threading it both internally and externally, and using Loctite 609 to secure it in place shows attention to detail and a thorough approach to the repair.
05-03-2024, 12:57 AM | #6 | |
05-03-2024, 06:49 AM | #7 |
The original screw was 10-32.
05-03-2024, 11:56 AM | #8 |
Thanks
I modified my original post
