Old 05-01-2024, 11:51 AM   #1
freak
freak's Avatar
Default Ford Model A rail inspection car
Interesting conversion.
freak is offline   Reply With Quote
Old 05-01-2024, 01:30 PM   #2
Brentwood Bob
Default Re: Ford Model A rail inspection car
Spins 180 degrees to reverse direction?
Brentwood Bob is offline   Reply With Quote
Old 05-01-2024, 01:45 PM   #3
Canton_Model_A's
Canton_Model_A's's Avatar
Figured you would just put it in reverse
1929 Model A Tudor - "Darla"
'29 Model A: Old enough to start with a crank, young enough to steal the show!
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 05-01-2024, 01:55 PM   #4
Brentwood Bob
More gears going ahead.
Old 05-01-2024, 02:47 PM   #5
Chuck Dempsey
Chuck Dempsey's Avatar
Slick! Thanks for posting.
Chuck Dempsey is offline   Reply With Quote
Old 05-01-2024, 03:20 PM   #6
P.S.
Yes. There's a pivot in the center. You lower the rear and remove the drive chain from the trucks (leave them hanging on the car axles). Undo the pins and spin the whole car around 180 degrees. Replace the turntable lock pins and guide the drive chains around the other set of trucks. Raise the rear end of the car to tighten the chains, and go.
2024-2025 MAFCA Technical Director
P.S. is offline   Reply With Quote
Old 05-01-2024, 03:47 PM   #7
Brentwood Bob
You make do. Grease the chains if you have it.
Old 05-01-2024, 04:15 PM   #8
Chuck Dempsey
Looks like a nice little 'chain tension' jack in the back....
Old 05-02-2024, 07:31 PM   #9
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
If Model-As and Railroading interest you, then here is a few more to make you drool.....
https://www.fordbarn.com/forum/showthread.php?t=252641
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
