04-01-2024, 06:36 PM | #1 |
How tight should the...
Hello All,
How tight should the drag link and tie rod end plug be? How much play if any? Thank you. |
04-01-2024, 06:59 PM | #2 |
Re: How tight should the...
Zero play - but loose enough you don't squeeze the grease out and cause wear.
04-01-2024, 07:00 PM | #3 |
Just tight enough to get the cotter pins in to secure the plugs
Bob from Northport Northport, Michigan |
04-01-2024, 08:31 PM | #4 |
I read somewhere on the BARN that the 'nut' is to be tightened all the way down, then back it off one full turn.
04-01-2024, 08:52 PM | #5 |
Some where in my reading 25 foot pounds came to light.
04-02-2024, 06:59 AM | #6 |
There will be many opinions and some reproduction parts are not to original specifications |
04-02-2024, 07:36 AM | #7 |
This slide will help you:
Bob Bidonde |
04-02-2024, 08:11 AM | #8 |
Bob, where in era literature does that specification come from?
04-02-2024, 09:31 AM | #9 |
04-02-2024, 10:30 AM | #10 |
Not sure if this applies to Model As or not, (this is the only place I ever found anything about adjusting the drag link ends) but my 1965 Ford Truck shop manual says: "Tighten the threaded plug in the end of the socket until the spring is fully compressed (ball seat bottoms on spring seat). Then back off the plug approximately 1 turn to the point where the slot in the plug lines up with the cotter pin holes in the drag link. Install a new cotter pin through the end of the drag link to lock the plug
04-02-2024, 10:53 AM | #11 |
This is where the need for a spring of the same wire size, free length, and spring rate is optimal. Reproduction parts don't always match the OEM parts. The little slide that Bob posted on #7 is likely very close to bottoming the spring and backing it off a turn. The main thing is that the spring is stiff and near coil bind but not bound. It needs just a bit to absorb shock loads from hitting bumps and such. These type of joints weren't the best but they do function well enough when wear is minimal. Worn out balls & sockets should be repaired or replaced just like a worn out modern ball type joint.
04-03-2024, 06:36 AM | #12 |
I just put the Teflon pads in my car and it steers a little easier, see https://www.snydersantiqueauto.com/p...7730&cat=41738
The new pads will not fix out of round balls. In my opinion, the Teflon pads have the main advantage of not wearing the balls. If you tighten, or adjust the pads in the tie bar, check the toe in alignment. I had about 1/8 toe out after putting the new pads in my car. See page 375 of the Service Bulletins.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 04-03-2024 at 06:56 AM. |
04-03-2024, 10:42 AM | #13 |
Ditto on the Teflon pads/cups. HOWEVER, their use is akin to the rubber wishbone ball cover - don't expect a tremendous life and keep an eye out for slop or "mushrooming."
Joe K
Shudda kept the horse. |
04-03-2024, 03:06 PM | #14 |
Delrin may be a better choice for the pads as it will wear a lot better and not deform, but still is a slick plastic and softer than the steel balls.
04-04-2024, 05:30 PM | #15 |
Hello, as per last 3 posts , that was my reasoning also for using the plastic inserts, easier than replacement of steering arms ,again.
04-04-2024, 10:54 PM | #16 | |
04-05-2024, 06:10 AM | #17 |
You are welcome. I think others have covered the subject of how tight the pads should be. If all the parts are good you can screw the plugs in until the cotter pins can be inserted. The pads should be tight but not too binding. Some judgement is required. If the parts are worn out or in doubt then they need to be replaced. Just remember if you replace or adjust the tie rod to check the toe in after you are done. The instructions on Snyder's show how the parts should be used for the drag link and this is the same for the steel pads. See https://www.snydersantiqueauto.com/c...0New%20Von.pdf.
04-05-2024, 09:34 AM | #18 | |
http://www.standard-ptfe.com/propert...Steel%20Filled
04-07-2024, 09:32 AM | #19 |
I researched all of the Ford Service Bulletins 1928 through 1942 and there is no quantitative instruction about tightening the drag link and tie rod end plugs. I use the 25% spring compression technique because it makes the most technical sense to me. All I did find was qualitative text indicating the drag link and tie rod need to be able to rotate, and not be loose (no play).
Bob Bidonde |
04-07-2024, 08:50 PM | #20 | |
Thanks again, Don Jr |
