Old 03-11-2024, 07:22 PM   #1
Cool Hand Lurker
Cool Hand Lurker's Avatar
Default Can 12V horn from '50s' be adapted for 6V system?
Been looking for a cheap 6V beep horn but have 12V horn. Can the 12V horn be converted to 6V and still have the same volume ??
Cool Hand Lurker is offline   Reply With Quote
Old 03-11-2024, 08:14 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Can 12V horn from '50s' be adapted for 6V system?
Doubtful you will get the right sound,
Old 03-17-2024, 05:33 PM   #3
Westernswede
Use it. It will just sound sick. Thanks for letting me comment. I need 9 posts before I can do anything else on this forum.
Westernswede is offline   Reply With Quote
Old 03-18-2024, 03:11 PM   #4
slowforty
slowforty's Avatar
They sell converters that change six volts to 12 volts. Google it ,as I cant find the information I had. Worked good on my 12 volt siren
slowforty is offline   Reply With Quote
Old 03-18-2024, 11:34 PM   #5
Eagle43
Here's one that I bought recently that should work.
Eagle43 is offline   Reply With Quote
Old 03-19-2024, 01:06 PM   #6
Matt F
I have a few old 12 volt horns and a small 6-volt lantern battery. I use the battery to test the sound and the volume of the horns. Some don't work at all, others are surprisingly good. You may not know until you try.
Matt
Matt F is offline   Reply With Quote
Old 03-19-2024, 06:03 PM   #7
19Fordy
19Fordy's Avatar
I wonder if you could use a resister in the horn wire and drop the incoming 12V to 6V?
I think you need a 60 ohm resister.
Old 03-19-2024, 06:06 PM   #8
19Fordy
19Fordy's Avatar
Couldn't you reduce the 12V to 6V by using a resister on the line?
Old 03-19-2024, 06:47 PM   #9
koates
He wants to use a 12 volt horn on a six volt system. Placing a resister in line will only make the situation worse. The best way out is really to get a six volt horn. Regards, Kevin.
koates is offline   Reply With Quote
Old 03-19-2024, 06:49 PM   #10
drolston
drolston's Avatar
Maybe try a rheostat with adequate current capacity, like a heater fan motor controller. Adjust voltage down with the knob until you get the correct sound.
The wire from the horn relay to horn should connect to one end of the rheostat coil, and the other end of the coil go ground. The wiper, adjusted to 6 volts, would go to the 6 volt horn,
Old 03-19-2024, 06:57 PM   #11
koates
Read my post #9. What you are suggesting with a rheostat will only drop the voltage. He needs the voltage stepped up. Read the original question please. Regards, Kevin.
Old 03-19-2024, 07:04 PM   #12
paul2748
paul2748's Avatar
12 volt horns that operate on less than 12 volts usually sound like a sick cow. But then you cold be lucky and it sounds ok.
48 Ford Conv
56 Tbird
54 Ford Victoria
paul2748 is online now   Reply With Quote
Old 03-19-2024, 07:08 PM   #13
19Fordy
19Fordy's Avatar
Ok, I got it. My reading skills are lacking today. Thanks.
Old 03-19-2024, 07:46 PM   #14
Ken T
Ken T's Avatar
I have zero experience using one, but this might work.
https://thirdgenauto.com/product/6-v...verter-10-amp/
Ken T is offline   Reply With Quote
Old 03-19-2024, 08:11 PM   #15
drolston
drolston's Avatar
RTFQ!
Learned that as a freshman, but it got lost some time in the past 64 years
Sorry.
Old 03-20-2024, 11:55 AM   #16
Cool Hand Lurker
Thanks, Eagle43. I ordered a 6V to 12V converter shipped to my door for less than $10.
It was kind of fun to read all the posts here though. I understand why 6V-12V-6V gets mixed up. Most questions here are usually on how to run old 6V things after a conversion to 12V, not the other way around.
I had an old 12V horn that I wanted to run on my original 6V car and I got my answer.
Thanks!
Old 03-20-2024, 12:53 PM   #17
Jack E/NJ
Jack E/NJ's Avatar
> > had an old 12V horn that I wanted to run on my original 6V car and I got my answer> >
So does this mean your old 12v horn runs OK on 6 volts or not?
Old 03-21-2024, 11:16 AM   #18
Cool Hand Lurker
It makes sound. Sort of.....
When I get the converter in the mail we will see if it is better then.
Old 03-22-2024, 12:29 AM   #19
rjlester
I use one of these in my 54 Meteor to power a 12v power port, and a hidden Bluetooth transmitter in the ashtray. Also have a few USB charge ports. Works great.
I did have to replace it after I fried it by accident. Hooked up a charger for about an hour, forgot and had the charger on 12 volts. The battery and the rest of the electrics in the car were fine, but the 12 volt booster was dead.
Great booster, I highly recommend it.
rjlester is offline   Reply With Quote
Old 03-23-2024, 12:07 AM   #20
Eagle43
This is why I just buy the cheap Chinese ones which generally work fine until they don't. Check the voltage when you order them. A lot of them only go down to 10V not 6. I've fried quite a few over the years. Easy to screw up and let the magic smoke out.
