02-27-2024, 04:21 PM | #1 |
Wheels Rotating in Opposite Direction
Recently I reinstalled my transmission in a 1934 truck (smaller frame). I had to back off the rear axle to remove and reinstall the transmission.
I had some difficulty getting the male shaft teeth to align with the female universal knuckle joint. So my son and I lifted the back wheels off the ground a bit and rotated the wheels enough to align the shaft/universal. Right or wrong, we turned the wheels in small increments either forward and/or backward until we got alignment and the shaft pushed into the universal joint. We also moved wheels independently of each other. Yesterday, I attempted a test drive to check out the new transmission. However, the truck appears to be "stuck". The transmission wants to engage but the truck doesn't move. It feels like the emergency brake is on (but it's not). So I just jacked up the back end until the wheels were free. When I move the right wheel, I see the left wheel rotating in the reverse direction. I assume this is bad and the reason the truck is not moving. Any thoughts on what I might have done to create this problem? And better yet, what I should do to fix the issue and get them back moving in the common rotation? All comments are very much appreciated! Shel |
02-27-2024, 04:29 PM | #2 |
Re: Wheels Rotating in Opposite Direction
Sounds like two gears at once in the transmission. Maybe the shift forks weren't engaged in the grove when the top was put back on.
02-27-2024, 04:35 PM | #3 |
Your differential is working correctly. However thats not what is wrong with your trans .
I hope someone with more trans knowledge chims in Agree sounds like shifter forks and locked in 2 gears |
02-27-2024, 04:43 PM | #4 |
You're on to something!
There was some confusion whether the transmission shop did, or did not, intend for me to pull off the shifter housing assembly to fill with gear oil. I assumed (probably incorrectly) they already installed the forks correctly then installed a gasket and "set" the housing. Now I bet if I pull the housing, I will see the forks aren't engaged in the grove like you suggest. I'm going to pull the housing now and confirm if this is the issue. If so, I will reinstall the housing with the forks in the grove, then install a new gasket. This would be a great solution and outcome (and lesson learned). Fingers crossed. I'll repost with an answer. Thank you!! |
02-27-2024, 04:57 PM | #5 | |
Hey Shel ...... It may not be as bad as you think. For the two REAR wheels to rotate in opposite directions when turning one wheel on either side is normal because of the spider gears, or what is commonly known as the "differential". This is the magic that allows the two rear wheels to turn at different speeds while going around a corner. Pull the top shift mechanism. You may likely find the transmission is in two gears at once. Make sure all gears are in neutral and carefully replace the top. You're learning! Coop . |
02-27-2024, 05:06 PM | #6 |
Alan |
02-27-2024, 05:22 PM | #7 |
Love the quick replies and support!!
I pulled the housing and it looked like the two forks were in fact properly set in the two groves. See the picture where I simply laid the housing on its side as I pulled it. Are there any particulars on how the gears should be "aligned" when I reset the forks back into the groves and put the housing back on? Anything look unusual with the gears in the picture? They are all new and were sourced from Van Pelt and installed by a reputable shop in Sacramento Cal. Thanks |
02-27-2024, 05:35 PM | #8 | |
Looks like the 2nd-3rd slide is sitting too far toward the rear, partially engaging 2nd gear. Coop . |
02-27-2024, 05:37 PM | #9 |
The 2nd and third gear synchronizer isn't centered in the hub. Is the shift lever in neutral? Before you put the top back on put it on the ground and see if it will roll.
02-27-2024, 06:12 PM | #10 |
Perhaps a mismatch between the transmission top cover and the transmission itself? I agree that the 2nd-3rd slider doesn't look quite right.
It's hard for me to see in the pictures. |
02-27-2024, 06:15 PM | #11 |
02-27-2024, 06:18 PM | #12 |
I think I'm following.
Sounds like the larger gear ("second - third slide" connected to grove farthest from engine) needs to be centered so it doesn't engage the second gear below. I've manually pushed that gear toward the center. Next, it sounds like the gear shifter should be in the neutral position when I install it. I've attached pictures which I hope help show its current position. I do not believe it is in neutral but I don't seem to be able to change its position. You suggested putting it on the ground to see if it would "roll". Do you mean would the forks move side to side? If so, the answer is one moves and the other doesn't. In the picture where I am looking at the underside of the shift housing, the lower forks move left to right. The upper fork is locked in position. Is it possible to know what the right configuration should be for the neutral position? |
02-27-2024, 06:28 PM | #13 |
I meant to see if the truck would roll to eliminate the rearend as the problem. but in looking at the shifter tower the slots are not lined up for the shifter handle side to side as in neutral. The shift lever is in the low reverse fork so slide it to neutral and see if the shift handle will engage 2nd and third.
02-27-2024, 07:07 PM | #14 |
Success! You guys are awesome.
Just drove around the block after 12 months of 'dry dock'. I'm going to print off this thread and save it for my future reference and for future family owners. Thanks much. I learned a lot. Shel |
02-27-2024, 08:49 PM | #15 |
Good deal!
02-27-2024, 08:50 PM | #16 |
Shel, would love to see you and your truck in Castro Valley on Saturday the 9th for the March meeting of the Golden Gate Regional group of the EFV8CA. Go to goldengatev8.org for further info place/time.
Alan |
02-28-2024, 10:41 AM | #17 |
Thanks for the invite Alan. Not available on the 9th but hope to make the April meeting.
Shel |
02-28-2024, 12:16 PM | #18 | |
Just for your information in the future, ALWAYS replace the shifter mechanism with the shifter in NEUTRAL, as well as with ALL of the gears in NEUTRAL. Works every time! Coop . |
