Old 02-22-2024, 11:47 AM   #1
duke36
Default Re: Metal Stem Tire Valve question
Just to clarify, I believe Mr. Karr in post 6 is referring to vulcanized metal stems already installed in vendors' tubes, not vulcanized rubber stems with dust covers ?
Old 02-23-2024, 06:22 AM   #2
TomInCologne
TomInCologne's Avatar
coming back to this, if i may...
i was at my tireman this morning and this is what i found:
- i had the thin rimliners available but we did not put them into the rims because they were all (except one) very smooth on the inside
- one inside was corroded, that's being cleaned and coated with anti-corrosion and will spend the rest of its life as a spare wheel
- the hole in the rim is quite a lot bigger than the outside of the metal valve. is one of those rim washers/dust covers A-1500C (Snyders number) supposed to go in there?
Thanks in advance...
TomInCologne is online now   Reply With Quote
