Old 02-05-2024, 08:45 PM   #1
Tom Endy
Tom Endy's Avatar
Default counter balanced crank
Is there a supplier in the Model A Kingdom offering a counter balanced crank? Years ago, there was an engine shop in Whittier California offering such. The owner died a number of years ago and the place went out of business.
Tom Endy
Old 02-05-2024, 10:29 PM   #2
mcgarrett
Default Re: counter balanced crank
Do you know about these?
https://www.snydersantiqueauto.com/p...8743&cat=41685
https://cnc-motorsports.com/scat-7-a...1928-1931.html
mcgarrett is online now   Reply With Quote
Old 02-05-2024, 11:20 PM   #3
jeepguy1948
SCAT also makes one and there is at least one vendor selling the weights and will install them to the crank for a reasonable fee (the name escapes me at the moment0
jeepguy1948 is offline   Reply With Quote
Old 02-05-2024, 11:32 PM   #4
jeepguy1948
OK,I found him. Check out DanFast he sells the weights that you can have him weld on or you can have it done yourself. He also sell balanced cranks.
Old 02-05-2024, 11:39 PM   #5
JayJay
Steve Becker at Burt's puts balanced cranks in his rebuilds, I suspect that if you called him he could give you a referral.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 02-06-2024, 12:25 AM   #6
Y-Blockhead
Y-Blockhead's Avatar
SCAT has forged, counterbalanced cranks and rods. https://www.scatcrankshafts.com/catalog/
File Type: jpg Screen Shot 2024-02-05 at 9.26.00 PM.jpg (20.5 KB, 75 views)
Old 02-06-2024, 02:48 AM   #7
BrianH
I have a Model B crank that is counterweighted. You cut down the mains to Model A size and use a det of B rods..
BrianH is offline   Reply With Quote
Old 02-06-2024, 11:12 AM   #8
jeepguy1948
Apologies, it’s Dan4Banger that I have been trying to point you to (last night I said that it was DanFast (it was late, I was tired, oops). I think that he can provide anything you want in the area of a balanced crank
Old 02-06-2024, 06:37 PM   #9
Dave in MN
Dave in MN's Avatar
Tom,
The Burlington counterweighted crankshaft is an option also. I have used a number of them in the past. The link follows:
https://burlingtoncrankshaft.com/
Good Day!
Dave in MN is offline   Reply With Quote
Old 02-06-2024, 06:47 PM   #10
Slowplane
Slowplane's Avatar
You might check with Arlen Beiber (San Diego A's)
______________
Nothing Short of Right is Right
Slowplane is offline   Reply With Quote
Old 02-06-2024, 07:13 PM   #11
Gene F
Gene F's Avatar
If you can possibly afford it, call Snyders and buy the Scat crankshaft, and rods. Not everyone that supposedly has a super good reputation knows what they are actually doing. (Don't ask me how I know this).
Old 02-06-2024, 09:13 PM   #12
johnneilson
It should be a punishable crime to grind a C crank down to 1.625 A crank size
I have put C cranks in A motors with inserts and a 1.850 main dia
This allows for drilling to oil the rods and not comprising strength
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 02-06-2024, 10:07 PM   #13
DJ S
DJ S's Avatar
J
So a Model A block and main bearing caps have enough “meat” to be bored out to accept a “C” crank?
DJ S is offline   Reply With Quote
Old 02-06-2024, 10:26 PM   #14
johnneilson
No
The B/C crank has 2.0 mains
If reduced to 1.85 it will fit
The main caps 1 and 2 should be replaced
The rear main of a later A has enough material
The bearing inserts from a Saturn rod bearing work
John
Old 02-07-2024, 12:11 PM   #15
Flathead
Flathead's Avatar
That is very interesting, thanks for sharing that.
Flathead is offline   Reply With Quote
Old 02-09-2024, 09:02 AM   #16
Dave in MN
Dave in MN's Avatar
No
John
I have also done this two times and the end result is very good.
Good Day!
Old 02-09-2024, 11:37 AM   #17
Gene F
Gene F's Avatar
Originally Posted by Dave in MN View Post
Tom,
Good Day!
About how much does a Burlington cost?
Old 02-09-2024, 11:58 AM   #18
jeepguy1948
Why don’t you use the link that Dave thoughtfully provided and learn for yourself? I don’t think that Dan is trying to sell you one.
Old 02-09-2024, 10:27 PM   #19
Hitman
I don’t believe they’re made anymore.
Hitman is offline   Reply With Quote
Old 02-10-2024, 06:14 AM   #20
Synchro909
Synchro909's Avatar
That is correct.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
