Old 01-28-2024, 11:26 AM   #1
jeepguy1948
Default High Compression Head
I’m curious, do the “High Compression Cylinder Head’s) as sold by Snyders etc. have a different combustion chamber than stock or are they just shaved stock type heads? Put a different way; can you make a high compression head by shaving a stock head? FWIW, I already have one of Jim Brierly’s heads, I don’t actually plan to do this, I’m just curious.
jeepguy1948 is offline   Reply With Quote
Old 01-28-2024, 11:38 AM   #2
John
John's Avatar
Default Re: High Compression Head
The marketed "high compression " heads have a different shape combustion chamber. Due to the shape of the original Model A head, shaving the head will have little effect on the combustion ratio.
John is offline   Reply With Quote
Old 01-28-2024, 12:14 PM   #3
Bob Bidonde
Bob Bidonde's Avatar
This slide shows the differences between the various combustion chambers.
Bob Bidonde
Old 01-28-2024, 03:35 PM   #4
Fullraceflathead
Fullraceflathead's Avatar
The combustion chambers shape of the high compression heads is a much more efficient design than the original design.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 01-28-2024, 05:06 PM   #5
Pete
When dealing with very low numbers like a model A, just the increase in pressure has more effect than the chamber design.
The ideal chamber design seems to be ignored by the head designers so far.
Old 01-28-2024, 06:20 PM   #6
Synchro909
Synchro909's Avatar
Because no one has mentioned it yet, I'm beginning to doubt myself but don't the pistons in a Model A engine come above the top of the block? If so, shaving the head too much will result in them hitting the head. NASTY!
To put it bluntly, don't be tight. Buy a HC head that was designed to work at the higher compression ratio.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 01-28-2024, 11:39 PM   #7
jeepguy1948
I remind you Synchro that I only asked out of curiosity, I already paid up for a Brierley.
Old 01-29-2024, 09:03 AM   #8
nkaminar
nkaminar's Avatar
A shaved head will work just fine as long as you recut the piston clearance and check to make sure the valves will not hit. You have to take a lot off so you may get into the water jacket. I had a shaved head on my Model T which worked quite nicely. It was a "low head" to begin with so the compression ratio was fairly high. Quite a lot was taken off, over half an inch, so it was into the water jacket in places, but the head gasket sealed off those areas. I had to use shorter head bolts.
Old 01-29-2024, 08:02 PM   #9
Synchro909
Synchro909's Avatar
Missed that, sorry!
Old 01-30-2024, 07:19 AM   #10
nkaminar
nkaminar's Avatar
Pete had a valid comment when he said that the ideal design was being ignored. I agree with him. The racing flat heads for the Harley Davidson and Briggs and Stratton engines are more ideal. There may have been some custom heads with more ideal combustion chamber shape, but, in my opinion, none of the ones offered today are.
The incoming air makes too many sharp turns in a flat head engine, especially a Model A engine. It starts at the entry into the block where the air has to make a couple 90 degree turns before getting to the valve. Then it makes another sharp turn to go down into the cylinder as the piston retracts. The inlet port in the block should be angled upwards towards the valve with one port for each valve. Then the part of the combustion chamber that directs the air down into the cylinder should have a generous radius and plenty of area atop the cylinder to allow an easy path for the flow. The intake manifold is another restriction, but that is another subject.
Old 01-30-2024, 08:24 AM   #11
johnneilson
That’s interesting
The Yapp Lion and Rocket heads are very close to some Briggs Jr drag heads
Brierley has a close Harley Davidson design
Both of these work very well
There are others that require changing pistons but are marginally better
If you want more go OHV
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 01-30-2024, 11:18 AM   #12
Flathead
Flathead's Avatar
The "crowfoot" Winfield head is a good one, Jim Brierly's head looks good also. Both of these are different from each other. Harley put a lot of effort into their design making it worthy of consideration, they also got some good results with it on the track.
OHV is best, but if you can make a Flathead run strong you have something to be proud of.
I like my Flatheads.
Flathead is offline   Reply With Quote
Old 01-30-2024, 12:09 PM   #13
jeepguy1948
In my opinion, Jim Brierley is one of the truly great’s in the world of high performance banger motors. I feel fortunate to be able to acquire one of his cylinder heads, Synchro, it’s cool, I was just messing with you a bit. I always appreciate your input.
Old 01-30-2024, 12:44 PM   #14
johnneilson
I like FHs also but sometimes like to go a lot faster
It is all good old iron making ponies
J
Old 01-30-2024, 12:53 PM   #15
Jim Brierley
THANKS jeepguy!
Old 01-30-2024, 08:08 PM   #16
Pete
Keep in mind a Briggs & Stratton or Harley KR have distant similarity to a model A.
You can only expect their head designs to perform mediocre on a model A, which they do.
Old 01-30-2024, 11:07 PM   #17
Joe K
Joe K's Avatar
Vince Falter covers the various high compression heads frequently found.
He only deals in cast iron heads. Still, a fairly complete examination (including contrasting the various combustion chamber shapes) beginning at https://www.fordgarage.com/pages/ABc...comparison.htm
I believe Ricardo did a lot of pioneer work on combustion chamber optimization. https://en.wikipedia.org/wiki/Harry_Ricardo
Joe K
Shudda kept the horse.
Old 02-01-2024, 11:27 PM   #18
Pete
He who has the head on the engine with the biggest dyno sheet numbers, wins...
Probably still Ed Winfield.
Old 02-02-2024, 12:44 PM   #19
jeepguy1948
What is y’all’s opinion on the best head gasket for an aluminum head?
Old 02-02-2024, 01:10 PM   #20
johnneilson
No
The exit speed of mile 3 wins
Ha!
J
