Old 05-31-2023, 02:10 PM   #1
Roger W Gerow
Default Wing nut thread size '51 ford air cleaner
Have you ever dropped the air cleaner wing nut on top of the engine. Well I did and it crawled away. Anyway, what is the thread size? The local parts store probably has one. Thanks In Advance!
DD658
Roger W Gerow is offline   Reply With Quote
Old 06-01-2023, 05:34 PM   #2
TJ
TJ's Avatar
Default Re: Wing nut thread size '51 ford air cleaner
I believe they are 8-24. Your local Ace hardware would have them also.
Old 06-01-2023, 05:47 PM   #3
tubman
tubman's Avatar
That seems awful small. I'll dig out my stock air cleaner and make sure.
Old 06-01-2023, 06:55 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
It almost has to be something near 1/4-20, no?
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 06-01-2023, 08:44 PM   #5
paul2748
paul2748's Avatar
Most of the ones I've ran into were 1/4 - 20, maybe 1/4-28
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-01-2023, 08:56 PM   #6
tubman
tubman's Avatar
That would be my guess, but the stock aircleaner from my '51 is the original, so I'll have the definitive answer.
Old 06-01-2023, 10:07 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Probably 1/4-20 on the bottom to screw into carburetor, and the wing nut end of that stud is likely 1/4-28. My guess, and I'm stickin' to it!
Coop
T5 W/TORQUE TUBE
Old 06-07-2023, 09:13 PM   #8
tubman
tubman's Avatar
I dug out the orignal air cleaner for my '51 today. The top nut is definitely 1/4-20. It is a stamped wing nut with traces of bronze paint that was used on the engine. It was greasy and dirty so I left it to soak overnight. I can post a picture of it if you need to see it.
Old 06-09-2023, 10:59 AM   #9
Roger W Gerow
Thanks for all the information on the wing nut. Will be getting a new one soon!
DD658
Old 06-11-2023, 12:41 PM   #10
jimvette59
jimvette59's Avatar
Hi, is it a solid wing nut or a pressed steal one ?
jimvette59 is offline   Reply With Quote
Old 06-11-2023, 02:46 PM   #11
tubman
tubman's Avatar
Pressed steel. As I mentioned above, I can post a photo if needed.
