#1 | |
![]() Quote:
What happened to the guy claiming the car was his and was stolen 14 years ago? It must have been B.S. on his part. |
... what happens a lot is a person buys a frame and the seller keeps the title with numbers that match the frame. It could be an original Ford frame or one that has assigned numbers on it. The seller wants the title to use on another car. The person who buys the frame may or may not use and try to register it right away in his name. Then when you get to DMV, they tell you your title is already registered to somebody else.
#3 | |
![]() Quote:
You think that happens a lot? Or is that a theory. Guess it could happen. But not likely. |
I believe it does happen a lot. I just bought a 32 rolling chassis that had the VIN # ground off near the firewall. The other 2 VIN #s were still on the frame. I checked the #s at DOT office and the #s had already been applied to another car. However, I knew the previous owner wanted to keep the title and that was part of the deal.
