#21 |
Greetings Mr Model T. This is the information I said that I would send to you.
Engine Compartment Area 1 Radiator shell 3/8” holes 1927-February 1928 Oil breather pipe down and out December 1927-July 1927 Oil breather cap 1927-March 1929 Splash pans bolts in six places 1927-November 1928 Front solid engine mount 1927-November 1928 Engine pan side groove February 1928-June 1928 Valve chamber cover oil return tube above bolt 1927-May 1929 Gas shut off round forged 1927-April 1929 Gas sediment bulb different threaded 1927-May 1928 Inside gas tank 5/8” fittings seamed tubing 3/8” diameter 1927-March 1928 Carburators Zenith or Holly dowel pen to secure double venture 1927-May 1928 Choke rod 22” tea drop knob November 1927-November 1928 Forged choke bracket November 1927-December 1929 Early choke rod not seamed 1927 Throttle linkage square base 1927-June 1928 Timing pin 9/16” hexagon ¼” October 1927-January 1929 Intake manifold no vacuum hole 1927-February 1929 Electrical System Area 2 Abell starter ½” drive shaft 1927-June 1928 Offset starter rod 1927-March 1928 Positive ground strap multi-layered flat 1927-March 1930 Negative battery cable length 23 9/16” to 22 9/16” December 1927-March 1928 Generator P-2 side mount cut out December 1927-April 1928 P-2 early generators cadmium rear plates 1927-March 1928 Terminal box Ford script original rough edges 1927-June 1928 Banana pop out ignition cable 1927-June 1928 Distributor casting round indent above pop out 1927-March 1928 Distributor casting square notch for upper plate 1927-March 1928 Distributor caps raised double Ford script 1927-March 1928 Distributor upper plate one piece integral ball 45 degree angle February 1928-June 1928 Lower plate longer wire 1927-June 1928 Point block on driver’s side of the distributor 1927-March 1928 Slant pole coil Ford script; script was eliminated 1927-March 1928 Light switch rod engraved on-off-dim 46 ¾” 1927-March 1928 Open boil lightening switch assembly; Knurled no drain hole 1927-March 1928 Clipped corners on terminal block conduit and speedometer cable clips 1927-March 1928 Brake light switch flat along attachment legs 1927-June 1928 Cooling System Area 3 Initial 1928 radiator rectangular bracket for support rods 1927-June 1928 Radiators had 2 lower holes to attach the fan shroud 1927-February 1928 Radiator fan shroud had 3 clips to secure right head light wires 1927-Febuary 1928 Water pumps casting 3/8” hole in bottom 1927-April 1928 Packing nut cast brass or bronze 1927-December 1929 Two blades double thick fan 1927-1931 Fan belts reddish brown or black 1927-1931 Hoses black with red strip or red 1927-1931 Water return pipe center bend near radiator for power house generators 1927-October 1928 Ford script removed on outer pipes April 1928 Undercarriage Area 4 Front axel Ford script - 1” long - 5/8” script 5/8” long 1927-June 1928 January 1928-June 1928 Front spindle flange - no seals - 1/8” grease seal 1927-December 1927 January 1928-May 1928 Pitman arms - 1st ¾” square no grease seal flanges - 2nd 1/8” grease seal flanges - 3rd sector shaft hole 15/16” - 4th grease seal flange 13/32” 1927-November 1927 December 1927-January 1928 February 1928-May 1928 June 1928-Early 1929 Front radius rod thin tapered type round forged balls; Tubes welded on top 1927-Early 1928 Spindle connecting rods (tie rods) - no grease fittings - grease fittings 1927-December 1927 January 1928-September 1930 Drag link connected at inside edges 1927-October 1928 Spring perches 1/8” straight neck November 1927-April 1928 Front and rear springs Ford script 10 leafs clipped corners 1927-April 1928 After 500 cars, the 2nd battery support square bottom 1927-August 1928 Battery covered pressed steel slight contoured corners 1927-August 1927 Frame assembly cross members riveted to frame rails Front cross member was also front engine support Rear axle housing wells facing forward after 1000 cars March 1929 Differential housing ¾” between pinion bearing and round housing 1927-February 1928 Torque tube design 10” long 2” straight behind U joint 18” tapered section 1927-June 1928 Universal joint housing cap third design no reinforcing rib on the safety lug January 1928-April 1928 Narrow radius rods 1927-May 1928 Flywheel housing shield - ¼” gap between shield and engine block - Second design ¼” flange added at outer edge 1927-February 1928 February 1928-May 1928 Transmission case no mounting for emergency brake 1927-June 1928 Reverse idler gear shaft within 1 3/8” diameter wide collar 1927-June 1928 Speedometer gear cap marked 10 37 3:701 1927-March 1928 Running board brackets were forged 1927-March 1929 Front and rear fender brackets were forged steel Early 1928-Mid-1929 Fender brackets had square outer ends with ¼” bosses at the fender edges January 1928-June 1928 Wheels with narrow inner flanges were completely phases by August 1928 1927-August 1928 Exhaust Systems Area 5 Mufflers had 1” offset 1927-February 1929 Intake and exhaust manifold gaskets copper or brass 1927-January 1929 Original mufflers unfinished tapered body design unchanged through production 1927-1931 Rear muffler clamps resembled scrap steel 1927-March 1929 Original manifold washers 1927-August 1928 Instrumental and Controls Area 6 Earliest instrument panel had a line encircling the edge; Not recessed at lower holes 1927-January 1928 Stewart Warner speedometer 2nd style 1/8” wide rim narrow numbers January 1928-mid 1930 Gas gauge vertical oval opening with a flat lens; Block numbers in red “O” “F” 1927-My 1928 Ignition plate “ON” and “OFF” 1927-November 1928 Ignition key “A” 1928 1927-March 1928 Second choke rod 22” and 3/8” teardrop knob November 1927-April 1928 Mushroom bakelite gear shift ball November 1927-April 1928 Squeeze grip brake handle on left cowl 1927-June 1928 Service brake and emergency break use some mechanism 1927-June 1928 Smooth pedals , no ribs, Ford script one piece forgings 1927-February 1928 New wheels, drums, backing plates separate cross shaft put into production June 1928 Service brake cross shaft; 2 piece shaft pivoted between universal joint and frame 1927-Febuary 1928 Brake System Area 7 Actuated both the service and emergency brakes; Single eye top and clevis bottom 1927-mid February 1928 Brake drums were dimensionally different - early 1 3/16” - late 1 11/16” 1927-June 1928 start March 1928 Backing plates smooth; no reinforcement ribs; round adjustable cones November 1927-February 1928 Brake rods were adjustable with threaded clevis on the forward end December 1927-April 1928 First style return spring tapered with an open end December 1927-April 1928 Steering Column Area 8 First steering assemblies 7 tooth gear, 7 tooth column had a plain lower housing with a lubrication fitting on the upper side 1927-March 1930 Red steering wheel where made of a phenolic resin known as “Ford lite” 1927-February 1929 Steering wheel spokes 13/16” narrower with grooved rim “V” joint spoke rim junction January 1928-February 1928 Unique steering shaft style lower bushing was used with the earliest flight switch, Open bale light switch 1927-February 1928 The diameter of the steering worm sector was increased to 1 1/8” and the square end increased from ¾” to 15/16” which necessitated a change in the steering gear, pitman arm and bolt February 1928 First light switch handle nickel-plated stamped steel with ON-OFF-DIM below; On and dim were arrows; Letters and arrows were filled with black enamel 1927-February 1928 Top Area 9 1927 through 1931 Coupe Tudor top materials were coarse long-short grain artificial leather Fabrics used for Model “A” tops were unique to the era Authenticity is the prime objective Exterior visors for some 1928-1929 production cars were covered using the same materials as used on the top Steel roof moldings and drip rails were pre-painted to match the top material and installed after the body was painted Note any variation or defects in fit, materials, components, for workmanship, tailoring and finish Glass and Side Curtains Area 10 Laminated glass was used in windshields of all Model “A” 1927-1931 Doors, quarter windows and read windows used plate glass 1927-1931 Passenger car rear view mirrors 1927-March 1928 Mirror 2 ½” wide 4 ½” long initially they were square corners 1927-March 1928 Carpets Area 11 All Model “A” Fords had a floor covering 1927-1931 Front floor early carpers had a heel pad sewn in approximate size 8”x11”x1/4”. The pad was beneath the pedals, stopping short of the shifts 1927-March 1928 Front carpet of closed models had a stamped steel trim ring, black, crimped on to the carpet around the gear shift tower 1927-March 1928 Carpet binding was matched to each trim scheme Carpets had a cut out for the throttle and foot rest. It was finished with edge binding 1927-June 1928 Used until the hard brake was relocated Early Tudor sedans had a full width support on the front seats and a sewn in leather rest on the carpets 1927-March 1928 There was a pyramid patterned rubber pad, weather seal with a metal core around the steering column 1927-October 1928 Used with multiple disc clutch Floor board assemblies were 11/16” thick dipped with water repellent 1927 through 1929 Front floor board assembly #2 had no forward extension of the lower black metal support 1927-February 1928 Floor boards were trimmed with a brownish fabric anti-squeak webbing 1927 through 1929 Metal rubber boot on left-hand emergency brake 1927-June 1928 Base of accelerator foot rest was completely round 1927-June 1928 Interior Area 12 Ford closed body models used molded rubber door check straps 1927 through 1929 Door check attachment point on doors was much lower 1927-February 1928 Standard model hardware before was plain and plated bright nickel 1927-May 1928 Early head liners were wool matching the upper trip color 1927-March 1928 Cut out at or around the door dovetails 15/16” tap to bottom All closed passenger vehicles except soft tops had a curtain at the rear window. Standard models, curtains were plain cloth 1927-1931 Original rollers zinc or cadmium-plated and thinned ¾” diameter. 1927-1931 All brackets were bright nickel 1927-1931 Window slide arms for closed models. No dent notch on the slide arms 1927 until 1929 The color of interior moldings was generally close to the predominate color of the seat fabric Dash rail windshield post moldings were painted body color All vehicles had some kind of anti-squeak material visible at the end of the dash rail. Most were extensions of the dash panels. In 1928-1929, the anti-squeak was a small trim welt to match the seats. Trim Scheme – 1928 Tudor 55A grey cloth with a stripe (dropped in February 1928) - Seats piped 3-3-8-8 - Seats sides, seat faces, seat backs, doors and quarters were grey cloth with wool stripe with a strip of broad lace across the top of the doors and quarter panels - Back roof rail, windshield headers were plain grey wool cloth - Headliner – Grey napped cloth - Window lace trip welt was grey Wooster cloth - Cowl, seat bottoms were grey Colonial-grained cardboard - Blue cloth window curtain had no pattern or pull tab - Window cord were mercerized blue with braided cotton cord. Sheet Metal Area 13 Hoods had 2 piece black leather corners sewn with a double lock stitch along both edges and a staple near the top of the stitch line 1927-January 1927 First style hood shelf was ¼” staggered ½”- 1 ½” 1927- March 1928 Hood bumper and bracket assembly. Flat bumper added to inner edge of the hood shelf 1927-March 1928 Hood shelf panel had a rolled reinforced edge on the outside 1927-Juley 1928 Hood hook sockets with round corners 1927-early 1929 Front and rear fenders had serrations completely around the rolled edges 1927 through 1929 Front fenders were curved at the inner skirt at the rear of the hard shelf. These fenders had a metal reinforcement spot welded on the inside of the fender bead at the bracket hole 1927 through July 1928 in some plants The height of the flange attached to the running board was decreased from 1 1/8” to 13/16” January 1928 The front fender skirt was changed increasing the sweep at the front to provide additional clearance at the shock arms February 1928 The fender brackets reinforcement was changed from flat stamped steel to a steel forging spot welded to the fender April 1928 The reinforcing plates for both the fender brackets and running boards were flat 1927-June 1928 Anti-squeak welting was installed between the fender and running board 1927-January 1928 Running board shield Type 1 splash aprons with early brake systems were secured to the body blocks 1927-July 1928 Splash shields did not overlap the frame from the cowl rear word 1927-July 1928 Running boards were sheet metal with rubber matting and zinc edge trim 1927 through 1929 Running board matting was a ribbed pattern running the length of the board 1927-1929 Painting Area 14 Some early cars were all one color with no contrasting reveal color Passenger cars had exterior striping at 1/8” to 3/32” wide stripe On the down grey Tudor, the stripe would be straw Trim color refers to the secondary color used on the belt moldings and/or upper body on Model “A” In 1928 and 1929, the trip color was applied only on the raised portions of the moldings. It didn’t extend into the doorpost and door jams. Gas tank in the passenger compartment were painted the lower body color Exterior Plating Area 15 Closed end front and rear bumpers varied in curvature. The outer radius was 11 ½”. Afterwards, the radius was 16 ½”. November 1927-February 1928 After pre-production, vehicles second style bumpers were 3-piece assemblies with two bars connecting plates with closed end bolts October 1927-March 1928 Front and rear bumper clamps had a 1/64” shallow relief 1927-April 1928 Rear bumper clamps were marked “Made in USA” 1927-April 1928 Radiator and gas caps were low or high domed 1927-March 1928 Filter screens served as a flame arrestor 1927-1931 Original filter screen unplated brass 1 ½” diameter 5/8” shorter 1927-May 1928 All 1928-1929 headlamps were acorn shaped and bright nickel. Initially, they did not have any markings. 1927-March 1928 Lamp and horn conduits were ½” in diameter used on vehicles equipped with fluted lenses. 1927-February 1929 Radiator shells with round holes for lacing and the rare crank hole cover with a vertical finger grip 1927-February 1928 (25,000 cars) Blue vitreous Ford radiator emblem with a stepped edge 1927-April 1929 Accessories Area 16 Restored vehicles are judges in comparison to the typical Model “A” Ford as it was driven off the assembly line Ford authorized Dealer supplied accessories Tools Area 17 Each Model “A” was equipped with a tool kit At the introduction of the Model A Ford, it was an engineering requirement that some of the tools have the Ford script identification. This requirement was removed by the end of April 1928. Oil cans were used in “A” and “AA” through April 1928 The grease gun was produced by “Alemite.” Tool bag – Common sense fasteners were single twist snap fasteners 1927-May 1928 Tool bag had two common sense fasteners January 1928-May 1928 “Ford” script was on the jaw of the wrench 1927-April 1928 Ford script spark plug wrench - unpainted - black lacquer 1927-January 1928 February 1928-April 1928 Ford script pliers A17025 was unpainted 1 ¼” script across closed jaws 1927-January 1928 Ford script pliers were painted black; one handle was tapered to a screw driver February 1928 Ford script open end wrench A17015 7/16” and ½” 1927-April 1928 Screw drivers A17020 overall length was 8 9/16” fluted handle Jack A17080 1927-October 1928 Jack handle A17081 – 16” long, 7/8” wide, ¼” flat steel Tire iron spoon on one end of a round hole, on the other end to line up with the 15/16” hole to with the handle socket Tire iron A17019 was a straight-sided tool with no Ford script. Prior to February 1928, unfinished. It was painted black thereafter. All tire irons were 10” long Ford designed the first tire pump. The Ford script was on the right side of the tire pump pad. 1927-April 1928 Starting in January 1928, an instruction book was provided with every vehicle sold. In 1928, first book round shift lever ball, left-hand brake without book, multiple disc clutch Ford script lug wrench 11/16” used on vehicles with left-hand brakes (P/N A17036) 1” socket end 1” OD 7/16” deep. Second was January through June, 1 1/8” OD socket end. Lamps Area 18 Before December 1927, “Ford” script was at the top of the headlight-fluted lens. After December 1927 to early 1929, the script was relocated to the bottom. The headlight bar may be stamped with one or more “Ford” scripts along the tubular section of the bar 1927-April 1928 The rear lamp shell was stamped inward or outward with “Duolight” and “Ford” 1927-March 1928 Duolight on the drum rear lamp shell had lettering 7/32” high Script was dropped by March 1928 Rear license plate bracket on 1927 and some early 1928 vehicles had an embossed “Ford” script just below the word “Duolight” Earliest style brake light plug tail lamp socket used through March 1928 was round and completely ribbed. The second style had a flat section at the area of wire attachment April 1928-January 1929 Horn Area 19 From the beginning of production through 1927, horns had a square post plug-in connection instead of clips There were two styles of square post connections. The earliest with receptacles in the bottom and the later plugged in from the side. In December 1927, the clip design was introduced and both styles’ connections were produced through early 1928. Thereafter, only the clip design was used. Horn mounting bracket was 1” wide at the top edge 1927-April 1928 Patent date plate indicated date of manufacture R21928 February 1928 First and second variations had no markings 1927-March 1928 Windshield Wiper Electric - ODC1A large Ford script - Made in USA - 1927: S was backwards - 1928: Ford script in oval. Introduced January 1928 and discontinued early February 1928 - March 1928 – ODC1B was introduced |
