Old 07-18-2022, 08:31 AM   #1
Smokedtires
Smokedtires's Avatar
Default Original metal valve stem?
Hey all, in the process of replacing my tires. I have 4 new Firestones ready to go.
I want to install period accurate valve stems in the tubes. Does this look correct for my 1930 Roadster?
https://www.mikes-afordable.com/product/M1500BK.html
Smokedtires is offline   Reply With Quote
Old 07-18-2022, 12:04 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Original metal valve stem?
https://www.brattons.com/30-31-METAL...ductinfo/2240/
What you have is correct, but is missing the actual valve stem. See link
Mike Peters is offline   Reply With Quote
Old 07-18-2022, 12:12 PM   #3
Gary Karr
Gary Karr's Avatar
Are you looking for original stems and hardware or new replacements?
Gary Karr is offline   Reply With Quote
Old 07-18-2022, 01:04 PM   #4
lotsagas4u
I think the short dust covers are out of stock everywhere.
lotsagas4u is offline   Reply With Quote
Old 07-18-2022, 04:16 PM   #5
Smokedtires
New replacements. Would it be okay to run without the dust covers until/if they become available again?
Old 07-18-2022, 04:16 PM   #6
Smokedtires
That's what I was afraid of. Thanks
Old 07-18-2022, 07:48 PM   #7
nkaminar
nkaminar's Avatar
I have never used these. Do they seal well? Do you need to use some sort of adhesive or sealant? Why were they used originally? Could they be used to fix a tube that had a bad rubber valve stem?
Old 07-19-2022, 05:11 AM   #8
mhsprecher
mhsprecher's Avatar
They seal well if installed properly. An adhesive or sealant isn't necessary, but I bet some people use one.
Not sure why they were used originally, but I would guess that it was because the processes to make a rubber valve stem did not exist or someone had not invented that yet.
Can they be used to fix a tube that had a bad rubber valve stem? Probably. It depends upon where the problem is. You remove the original stem entirely. There must be a video of it somewhere. There was a discussion of how to do this at the MARC meet valve stem seminar in Morgantown in June.
1910 Model T Touring
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 07-19-2022, 06:21 AM   #9
Mike Peters
http://www.sheepisland.com/cars/tech/metal_stems/
Video on installing metal valve stems.
Old 07-19-2022, 10:52 AM   #10
katy
katy's Avatar
Replacement rubber stems for tubes are available:
https://www.amazon.com/Milton-473-Pa...%2C576&sr=8-13
Old 07-19-2022, 07:25 PM   #11
Ray in La Mesa
I've used the replacement stems & they work fine. I put some of Snyder's replacement '30 stems in my tubes, bought them 30 years ago at 1/2 the price they are now & they worked fine with no sealant, but, I had to fix three pin hole in the NEW tubes I bought 10 years ago.
Ray in La Mesa is offline   Reply With Quote
Old 07-20-2022, 06:53 AM   #12
Smokedtires
Thank you all. Some great discussions. I found the metal stems at Bert's and they are on the way. Will have to run without the dust covers until they're available once again.
