Old 02-09-2022, 07:25 PM   #17
1crosscut
1crosscut's Avatar
Default Re: Model AA cyclinder compression
Pull the wire out of the top of the distributor and hold it about a half inch away from a head stud nut and crank it over. You should have a good fat blue spark that jumps between the two.
If not run a piece of fine grade sandpaper between the points to remove any oxidation.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
