Old 08-24-2021, 05:11 PM   #1
red or green
Default Compression PSI
Hello to all in T land
I acquired a 1918 T Roadster awhile back, though it has electric start added and changed to a steel firewall.
It was running pretty rough and I started down the road of troubleshooting.
In the process, I took all the spark plugs out and performed a compression test.
40 PSIG on all four holes.
I'm doing this at 7000' elevation so if you add 25% compensating for altitude, round numbers, it would be 50 PSI at sea level
I am thinking that is in the ballpark of acceptable for a T engine.
Agree or disagree....??
I've got it running well, it's remarkable what rebuilding and timing coils will do in conjunction with a new timer!
Thanks
red or green is offline   Reply With Quote
Old 08-24-2021, 07:22 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Compression PSI
Your engine seems ok.
Old 08-25-2021, 07:22 AM   #3
red or green
I was thinking so,
Thank you for the confirmation
Old 08-25-2021, 09:05 AM   #4
redmodelt
redmodelt's Avatar
Even at sea level, 40 would be ok.
Old 08-25-2021, 11:41 PM   #5
G Baese
G Baese's Avatar
Hello there Mr Red or Green,
Is it the car or your drive way?
Its a great little car!
Cheers,
gb
G Baese is offline   Reply With Quote
Old 08-26-2021, 10:14 AM   #6
redmodelt
redmodelt's Avatar
Guessing, you are talking abut the cut off pickup? If so, thank you!
