08-05-2021, 04:13 PM | #1 |
53 distributor internal wires
Sure I’ll remember……NOT.
I seem to have two ground wires ( bare copper) and a wire from condenser to little nuts on points. Where does 6v to points come from? In other words, someone have a photo or maybe better, an explanation of what goes where. Only have one 53 dizzy, so nothing to look at. Thanks much. Gordon
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes.. |
08-05-2021, 07:58 PM | #2 |
Re: 53 distributor internal wires
You can see the wire to battery side the coil, then the wire from the distributor side of the coil, to the distributor, then into the points and condenser mount = power to the points.
The ground wire at the top (11:00 position - black arrow). Condenser wire on left (white arrow) and the coil wire on the right (white arrow). This is on a 1953 Mercury. Hope this helps. Last edited by Merc Cruzer; 08-05-2021 at 08:09 PM. |
08-07-2021, 02:23 PM | #3 |
That Coil Wire is technically supposed to be routed underneath the breaker plate (next to the ground wire), but it's a royal PITA (and usually have to take the distributor out) to do it.... but as long as it's not interfering with the rotor you'll be fine...
have a look here http://www.vanpeltsales.com/FH_web/F...r_1950to53.jpg Last edited by RusselS; 08-07-2021 at 02:25 PM. Reason: adding link |
08-07-2021, 02:37 PM | #4 | |
The diagram seems to show the coil wire, coming up under the bottom of the distributor, at the same location as the ground wire. On mine, the ground wire is at 11:00 and the coil wire comes into the distributor at 3:00. Last edited by Merc Cruzer; 08-07-2021 at 02:57 PM. |
08-07-2021, 04:45 PM | #5 |
The ground wire is indeed connected to the body of the distributor at the bottom with this screw.
08-07-2021, 05:09 PM | #6 |
have a look here http://www.vanpeltsales.com/FH_web/F...r_1950to53.jpg Interesting, I will see if I can do that. Seems like it shouldn't be too big of an issue to thread it under there. "famous last words" Thanks for the clarification. Later: Something like this.......easier than I thought, until I dropped the nut behind the plate. Got it out with a magnet. If I am going to post pictures, the least I can do is make sure they are correct. Thanks again for helping me correct it. Wonder where I can find the little rubber gourmet, the coil wire go through, at the bottom of the distributor? Last edited by Merc Cruzer; 08-08-2021 at 09:54 AM. |
08-08-2021, 08:03 PM | #7 |
so... it's supposed to be a post you can see the rounded rectangular post in the photo... and it's 350032-S in the parts link.
and the coil wire is supposed to have a flag terminal that goes through the top of the post and then underneath is a threaded post the distributor wire connects to. hope that helps |
08-08-2021, 09:06 PM | #8 | |
08-08-2021, 11:54 PM | #9 | |
There is nothing wrong with not using it. When converting to electronic ignition the connector is removed and a wire thru a grommet is substituted.
08-09-2021, 08:29 AM | #10 | |
Thank you for the pictures. I now understated the configuration for the wire. I will search for the parts, just to have them, in the event I decide to return the distributor back to its original design. Per your insight, I think I will stay with the single wire for now, since it has not been an issue, anytime in the past, and will search for a grommet, for the wire. I think if I had been an engineer for Ford/Mercury, back in the day (which my dad was, and I remember him talking about the cost saving, with the elimination of a single spring, in the wiper), there would have been a single wire design submitted, as it would have definitely resulted in a cost saving, for the production of the distributor. Thanks again, Merc Cruzer Last edited by Merc Cruzer; 08-09-2021 at 12:07 PM. |
